Pocket GPS World :: View topic - Computer fails to recognise Nuvi 300
sugar-matrix
PostPosted: Mon Oct 22, 2007 11:55 pm    Post subject: Computer fails to recognise Nuvi 300 Reply with quote
I love my garmin but it keeps giving me jip ! I am unable to update from ver 2.20 my computer (vista) and my OH's computer (XP) do not recognise the unit, it also keeps saying this traffic thing is not supported and I haven't a clue what to do, please help Crying or Very sad
sugar
philpugh
PostPosted: Tue Oct 23, 2007 1:11 pm    Post subject: Reply with quote
Not a lot to go on but..
Are you getting connected to the PC? That is - does the unit go into mass storage mode ("computer" icon on top of the nuvi startup splash screen)? This should give you two additional drives on the PC (the nuvi internal and the SD slot). You may need to use the GARMIN supplied USB cable to do this.
When you run Webupdater does it see the nuvi?
What messages (if any) are you getting?
As for the TMC unit - which one was supplied (GARMIN unit number will do) possibly something like GTM12.
Are you getting the message when pluggng it in or when?
Phil
tynecomp
PostPosted: Tue Oct 23, 2007 2:11 pm    Post subject: Re: Computer fails to recognise Nuvi 300 Reply with quote
Which USB port on the Nvi are you plugging the cable into? It needs to be the one on the side not the one on the back. If that isn't the problem then describe in more detail what you are doing and what happens.
sugar-matrix
PostPosted: Tue Oct 23, 2007 10:45 pm    Post subject: Reply with quote
The unit fails to go into MAss storage mode and just loads up as normal.
I'm using the cable supplied in box, and plugging it in to the side by the SD slot.
Webupdater fails to recognise the unit, as do the usb driver thingy !
And it keeps saying this accesory is not supported while I'm driving using the unit, and I have to keep touching the screen to remove the msg.
I'm so fed up I can't find the reciept, otherwise I would of taken it back to argos.
Please help I have such a headace trying to make it work Crying or Very sad
sugar
JoshT
PostPosted: Wed Oct 24, 2007 3:58 pm    Post subject: Reply with quote
Have you been to the Garmin website and downloaded the latest update?
Changes made from version 4.90 to 5.00:
Corrected issue where WebUpdater may not find device [/b]
URL is: http://www8.garmin.com/support/collection.jsp?product=010-00455-01
I suggest you download the zip file onto your pc hard-drive then install rather than use web-updater.
philpugh
PostPosted: Wed Oct 24, 2007 5:21 pm    Post subject: Reply with quote
Good call!
Mind you a Major s/w upgrade (going by the numbers) to fix just one (relatively small) problem?? What gives GARMIN?
sugar-matrix: You mentioned "USB driver thingy" in your last post - you shouldn't need this with XP and/or Vista as far as I recall.
Phil
sugar-matrix
PostPosted: Wed Oct 24, 2007 8:29 pm    Post subject: Reply with quote
downloaded and unziped the file onto computer, but as the computer doesn't recognise the unit, I can't upgrade the sw as it doesn't see the nuvi, have asked the program to find the drive but it still doesn't see it, now seriously considering buying another from argos and returning this one and getting my money back as I don't have proof of purchase, this is soooooo poo !!! Crying or Very sad
sugar
oddsock
PostPosted: Wed Oct 24, 2007 9:54 pm    Post subject: Reply with quote
Have you tested the usb lead on another device ie camera or a camera or mobile phone lead with your Nuvi??
TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
sugar-matrix
PostPosted: Wed Oct 24, 2007 10:11 pm    Post subject: Reply with quote
Yep tried several leads none work with the nuvi, but all work with my camera, it booted up before and the screen was split in 4 with the picture peices all in the wrong order, Looks like a trip to the local Argos tomorrow !
sugar
philpugh
PostPosted: Thu Oct 25, 2007 9:01 am    Post subject: Reply with quote
sugar
You need the GARMIN supplied lead get it to go into Mass Storage mode as far as I know. My 660 certainly won't go into mass storage with any miniUSB-USB cable I own (and that is lots!) only with the supplied GARMIN lead.
Phil
JoshT
PostPosted: Thu Oct 25, 2007 9:14 am    Post subject: Reply with quote
I'd try three things before going back to Argos
1) Try hard ware reset on your device
2) Check other programs on the PC are not hogging the USB port on the computer. Check bottom right hand corner of windows screen and see which applications are running. You may have a camera, phone, MP3 application running which is already using the USB port. If so, right click on application icon and close the application.
3) Uninstall and reinstall Garmin applications - Web updater, poiloader
oddsock
PostPosted: Thu Oct 25, 2007 7:22 pm    Post subject: Reply with quote
It may be unit specific that it does not work with the 660 because I have used usb cables from my card reader,spv500 phone and vivitar camera and they work ok on a Quest,gpsmap60c and a nuvi300 .
Edit: but I realise that the latter is the only one that has mass storage.as do the 3 items I can use the leads from.
Garmin Quest
sugar-matrix
PostPosted: Sat Oct 27, 2007 10:23 pm    Post subject: Reply with quote
Got my new Garmin nuvi 300 and it works a dream, lobbed the poorly one back in the box and took it back to Argos and got a refund, now that was certainly easier and less stressful than sending it back to Garmin !!!
I'm happy the nuvi is happy, and it updated Laughing
sugar
tonygamble
PostPosted: Tue Apr 08, 2008 7:23 pm    Post subject: Reply with quote
I'm popping this up as I'm having problems with a 760 and maybe someone has this thread flagged for e:mail and can help.
Tony
22.064 (26 Jun 24)
