Mozza00 Occasional Visitor
Posted: Sat Oct 20, 2007 12:39 am Post subject: Nuvi 310 - Speaking Street names |
Hi new to the forum and have recently purchased a nuvi 310.
Was wondering if it was possible to flash the 310 with 350 software in order to get it to speak street names or is there another way?
Also doesn't seem to be detecting speed cameras, is it it or me?
Cheers,
Mozza |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Sat Oct 20, 2007 11:16 am Post subject: |
No, firstly the 350 firmware is not compatible with the 310, and will break the unit. However, if you meant the 360, I'm afraid you are out of luck - the 310 and the 360 share a common firmware; once the firmware is loaded is works out which hardware you have and enables / disables the TTS based on the hardware.
Secondly which speed cameras, the Garmin ones or ones downloaded from here? If PGPSW, what have you done so far with them (eg what did POI Loader report when it loaded them onto the unit), which files did you use, and what do you see if you go to Where To? Custom POIs...? _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Mon Oct 22, 2007 11:00 pm Post subject: |
Hi cheers.
It was garmin ones, tho will install the ones off this site.
Mozza |
philpugh Lifetime Member
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Tue Oct 23, 2007 3:35 pm Post subject: |
Check you've got the Proximity Warnings set fr the GARMIN speed cameras _________________ Phil |
