Pocket GPS World :: View topic - 210T, PE software and POSTCODES
b1ackb1rd
PostPosted: Sun Sep 30, 2007 6:32 pm    Post subject: 210T, PE software and POSTCODES Reply with quote
Managed to update my PNA210T with PE software which I think is brilliant, but I cant get the postcodes to work correctly ... I'm stuck on 5 character postoces only which is annoying.
Can anyone help please?
Fatboyfun
PostPosted: Mon Oct 22, 2007 1:30 pm    Post subject: Reply with quote
Did you get this sorted? I have the same problem.
b1ackb1rd
PostPosted: Tue Oct 23, 2007 3:57 pm    Post subject: Reply with quote
Not yet, anyone any ideas??
Can a TT zip file be converted and popped in?
Fatboyfun
PostPosted: Tue Oct 23, 2007 5:13 pm    Post subject: Reply with quote
Tried that by renaming it to gbpostcodes.upd and then poiedit will open the file, then i converted it back to gbpostcodes.asc and placed it in various directories on the unit while hard reseting but nothing works.
Fatslag
Banned
PostPosted: Fri Oct 26, 2007 4:58 pm    Post subject: post codes Reply with quote
You can input addresses using eight digit post codes, plus it has neat touches such as possible road names being clearly listed in radio buttons across the top of the screen, changing as you tap in additional letters. It also gives you the option of being directed to the middle of the street if you don’t know, or can’t be bothered, to enter the number.
I think maybe your update or upgrade has not been sucessfuly done
monkeyseemonkeydo
PostPosted: Tue Dec 11, 2007 9:10 pm    Post subject: Reply with quote
Has anyone had any luck with this? I've just upgraded the software on my 210T and am having the same problem: Used to be able to use 7 digit postcodes but am now limited to 5... Think maybe I didn't follow the instructions correctly but would like to know if there's a quick fix.
Fatboyfun
PostPosted: Wed Dec 12, 2007 12:14 pm    Post subject: Reply with quote
I've not managed it yet, I think the postcodes were in the maps themselves, the maps with version 2 (Original with postcodes) were larger files than the updated maps. To be honest i think it's not possible with the current update. Maybe we could wait for Gopal 3.1PE UK version to become available as an update. as seen on the Medion Gopal E3410
http://64.233.183.104/search?q=cache:ea1Zpc4xJWoJ:www.re-source.co.uk/html/satnav_0.html+gopal+3.1+pe&hl=en&ct=clnk&cd=2&gl=uk
monkeyseemonkeydo
PostPosted: Wed Dec 12, 2007 2:17 pm    Post subject: Reply with quote
I've been reliably informed that the postcode accuracy is determined by the version of the software you use, i.e. CE vs AE vs ME etc. I think I may therefore revert back to the standard software and try just installing all the necessary maps, poi's etc after that. Won't look as pretty but will be more functional...
