Pocket GPS World :: View topic - Whats the current version of TT6 for PDAs
rgreenpc
PostPosted: Fri Feb 16, 2007 5:47 pm    Post subject: Whats the current version of TT6 for PDAs Reply with quote
Someone told me he has a newer version that I do 6.03 but he has a non-pda version and I thought the two followed different version trees.
philpugh
PostPosted: Fri Feb 16, 2007 6:32 pm    Post subject: Reply with quote
The official supported PDA version is 6.01 UNLESS you have a particular PDA which requires 6.03 to fix a problem.
Go to the TT website www.tomtom.com and follow the links for the PDA upgrade - it lists the appropriate PDAs.
However you can download 6.03 and try it on your PDA - it does work on my AXIM X51v - but I won't get support from TomTom - but I won't lose sleep over that.
FWIW in my experience 6.03 seems to be a lot smoother visually and has a different routing algorithm compared with 6.01. It stops trying to route me onto a road that is several metres under me on my way home.
Phil
limeburner
PostPosted: Sat Oct 06, 2007 12:56 pm    Post subject: Reply with quote
is 6.03 still the newest version of TT navigator?
PostPosted: Sat Oct 06, 2007 3:42 pm    Post subject: Reply with quote
Yes for the devices that use it, you need to check the TomTom web site to find out if your hardware requires 6,010 or 6,030 - Mike
limeburner
PostPosted: Sun Oct 07, 2007 7:45 am    Post subject: Reply with quote
What about 6.02??
PostPosted: Sun Oct 07, 2007 8:30 am    Post subject: Reply with quote
There is/ was a version 6,020 but as far as I am aware it was only supplied pre-installed to certain hardware with built in GPS receivers, the HTC Artemis was one such device with 6,020 installed. Interestingly upgrading the unit to WM6 (the official ROM from the manufacturer) you loose the in built TomTom and have to install it manually - Mike
limeburner
PostPosted: Sun Oct 07, 2007 1:35 pm    Post subject: Reply with quote
Mike, thanks for the info
trafcam
PostPosted: Mon Oct 08, 2007 9:35 am    Post subject: Reply with quote
According to some of my customers, TomTom Home upgrades them to version 6.030 regardless of whether they have one of the specific PDA models that the web site says the fix is for. And anything written with the SDK doesn't work on 6.030, until TomTom release an updated SDK.
aj2052
PostPosted: Tue Oct 09, 2007 2:32 am    Post subject: Reply with quote
if any help v6.030 runs quite happy on my Mio168 PDA, it also has a new start up screen,seems to run a bit slicker aswell.
Calomax
PostPosted: Wed Oct 10, 2007 8:22 am    Post subject: Reply with quote
I found a very definate improvement in the way TTN 6.03 runs on my iPAQ 1940 after previously running versions 5.21, 6.00 and 6.01.
TT Go Essential
Calomax
PostPosted: Wed Oct 10, 2007 8:47 am    Post subject: Reply with quote
TT Go Essential
