Pocket GPS World :: View topic - MYGUIDE 3100 Ac Adaptor
poddington44
PostPosted: Mon Aug 27, 2007 2:52 pm    Post subject: MYGUIDE 3100 Ac Adaptor Reply with quote
Could someone please help? I'm trying to find the best place to buy an AC adaptor for my MYGUIDE 3100 but can't seem to locate one Crying or Very sad
PostPosted: Tue Aug 28, 2007 2:24 pm    Post subject: Reply with quote
Any 5 Volt 2 Amp AC adapter with the right size DC plug for the socket on your machine should do fine.
Or you could contact MyGuide at http://www.my-guide.de/en/info@myguidegps.com
The original AC adapter is part number E-AWB100-050E (There may be a different suffix for the UK).
- Incidently, the speed-cam forum is a bit of an odd place to post this, if there isn't a forum section for MyGuide, you could try the "Other PND" section for hopefully better answers than mine.
Buffdaddy
PostPosted: Tue Aug 28, 2007 7:31 pm    Post subject: MYGUIDE 3100 Ac Adaptor Reply with quote
If you are unable to get an adaptor, you can charge your device by inserting the USB connector that comes with your myguide 3100 into to the USB port of your PC. Obviously this is when your PC is on and you happen to be doing something like browsing this site.If you use your device quite frequently, not allowing it to go below 60% battery charge, it will be back to full charge in less than an hour.
poddington44
PostPosted: Wed Aug 29, 2007 3:22 pm    Post subject: Reply with quote
Thanks For The Help Guys Very Happy
22.071 (03 Jul 24)
