Freeman82 Occasional Visitor
Posted: Fri Aug 17, 2007 10:37 am Post subject: Which in Car Nav system should I get? |
I'm looking to get an in -car sat nav system.
I have a few requirements:
Cheap(ish) - up to £150
Needs to be switched between cars
Preferably NOT charged from the cigarette lighter
I'm not fussed about European maps, I only drive in the UK.
I was looking initially at a Navman F20, but most folks are telling me to go for a TomTom (I assume tomTom One for that price range), but one guy has suggested a Garmin, and someone else has said to look at a Myguide 3100.
So now I'm lost in the woods and needing a guiding light.
thanks. |
GJF Frequent Visitor
Posted: Fri Aug 17, 2007 11:17 am Post subject: Re: Which in Car Nav system should I get? |
Freeman82 wrote: | Hi,
Cheap(ish) - up to £150 |
Quote: | I was looking initially at a Navman F20, but most folks are telling me to go for a TomTom (I assume tomTom One for that price range), but one guy has suggested a Garmin, and someone else has said to look at a Myguide 3100. |
Your choice of Sat Nav does come down to more than a suggestion from a friend, as they often do different functions on different makes and your own "want list" is a good starting point, eg i believe, having bluetooth to pick up with the mobile phone is a must for an "extra".
I presume we are talking about new here, a Garmin StreetPilot i3 is around £100, Garmin Nuvi 300 around £135 and a Garmin Quest around £175, i am not that familiar with these as i have the Garmin 660 (which i love), but i'm sure others will comment.
Quote: | Preferably NOT charged from the cigarette lighter |
All the Sat Nav's come with the plug to the cigarette lighter, it can be wired straight into the car (hard wired) but this would leave the unit fixed long term and not removeable.
Also most units have a voltage reducer and fuse within the cig lighter plug so if you are not carefull you end up blowing the unit up if other precautions aren't taken.
The best way to eliminate the cig lighter plug is as explained HERE but this does make it difficult to move in a hurry.
Quote: | Needs to be switched between cars |
If you have the Sat Nav "hardwired" this isn't so easy, the only way to be able to do this is using the cig lighter plug supplied.
I know this doesn't answer your question's in full, but hope it is some help. _________________ TomTom Go 60
Garmin Nüvi 660, Firmware v4.90
Drive-Smart GPS with Loader v1.4.16
HTC Advantage X7500 MS 6.1 Tchart Speed Sentry
Satmap Active 10, Software v1.16
Fuzion 32 HUD Bluetooth GPS receiver |
Posted: Fri Aug 17, 2007 11:25 am Post subject: |
The reason for my not wantibng to use the cig lighter is twofold.
I have use of several vehicles depending on where I'm going and what I'm doing:
In my Golf using the ciggie lighter is fine.
However the other two vehicles this will get used in are American so have a different sized ciggie lighter socket (and on one of these vehicles said socket doesn't even work). |
portman Frequent Visitor
Posted: Fri Aug 17, 2007 11:31 am Post subject: |
Don't go for the tomtom ONE as it only lasts 2 hours on its battery, the Garmin Nuvi is a better bet as it will last 4 hours. _________________ Samsung Mega
Tomtom 500
Posted: Fri Aug 17, 2007 3:10 pm Post subject: |
Freeman82 wrote: | The reason for my not wantibng to use the cig lighter is twofold.
As for the American cig lighter not working, other than getting it to work - not sure what the answer is.
I would have thought it wouldn't be too difficult to buy the American lead to whatever Sat Nav you buy, so as to fit American cig lighters, Garmin might be an advantage in your choice of Sat Nav as it is American and in wide use throughout the States.
As stated before all the Sat Navs have cig lighter plugs, so although the cables look a mess, this route is the only easy answer to your request for unit mobility. _________________ TomTom Go 60
Posted: Fri Aug 17, 2007 5:00 pm Post subject: |
OK, so at the moment, the Garmin's winning.
the TomTOm One has a 2hr battery
the Navman 4hrs
Acording to satnaveasy.co.uk the Garmin has up to 8 hours. I'm guessing that's optimistic, but it's still miles better than the other two.
So what are thoughts here generally on the Garmin Nuvi 310?
http://www.satnaveasy.co.uk/item.do?item=12&gclid=CK_xkOH1_I0CFQc8EAodphNtNg |
Posted: Fri Aug 17, 2007 5:16 pm Post subject: |
The 310 is a very capable device if you do go for one make sure it has the latest V9 mapping loaded or available free of charge though, that said I hate the Garmin user interface it simply is no where near as intuative as the HMI TomTom units offer - Mike |
old_nick Occasional Visitor
Posted: Sat Aug 18, 2007 8:52 pm Post subject: |
If you are new to Satnav I would recommend the Navman F20 as it is the easiest I've ever used. The MyGuide has a lot more features than the Tomtom one, but the interface can be very tricky to find your way round. They all use Tele Atlas Mapping.
Garmin uses Navteq mapping and in my opinion make the best Satnav's. I wish i had never got rid of my i3 as it was a great little unit, it would last up to 6 hours on 2 AA NiMH rechargeable batteries, ideal if you need to keep swaping vehicles. |
aj2052 Frequent Visitor
Posted: Sun Aug 19, 2007 1:39 am Post subject: |
Im surprised that pnd versus Pda doesnt come into the equations, i would have thought that the extra database, spreadsheets,word facilities, etc would count for somebody who spends a lot of time on the road given the extra facilities, being a long time user of PDAs i wouldnt decry PNDs because they are improving quite a lot now but PDAs would be my preference because they fulfill my needs precisely. |
Posted: Sun Aug 19, 2007 9:58 am Post subject: |
aj, A very good point about PDA units, however with £150 to spend this is going to be a tall order.
I would have a look at your mobile phone supplier and possibly consider something like a T Mobile Compact MDA-III as they are PDA based with the GPS built in to the device and can be obtained for free.
That leaves your budget to be spent on software (£100) and a decent car holder (£50) - then you will have a quality set up that can do considerably more than just the navigation you get with the PNA - Mike |
