Kozak Occasional Visitor
Posted: Mon Jul 23, 2007 10:23 pm Post subject: Trip planning with tomtom One |
Just got the unit and am having trouble mapping a route. Can someone explain to me what is the best way to map a route. I am going from Philly to NY and don't like the route it suggested. I now how I want to go, but how do I tell it I want to go from point A to point B, then point B to Point C, ect... To be more exact I want to take I95 to 31, 31 to 202, 202 to 287.... What is the easiest way to do this? Thanks |
gardenshed Frequent Visitor
Posted: Mon Jul 23, 2007 10:54 pm Post subject: |
tap screen
press right arrow
tap itinerary planning
enter the locations to want to travel via using the add button and the menus it brings up :D
hope that helps |
Posted: Mon Jul 23, 2007 11:21 pm Post subject: |
Do I have to know the names of the cities were the highways intersect? I guess I'll have to look up the cities. I was hoping there was a way just to enter the names of the two highways that intersect. |
Posted: Tue Jul 24, 2007 12:09 am Post subject: |
gardenshed wrote: | tap screen
press right arrow
hope that helps |
I don't see itinerary planning. Is it called something else? |
FazerUK Lifetime Member
Joined: Nov 18, 2004 Posts: 242 Location: Wrexhaml, UK
Posted: Tue Jul 24, 2007 12:12 am Post subject: |
it looks like this
Then this
_________________ TomTom Go 700,
with External Antenna, External Mike
App v7.160, OS:2324, GPS v1.21, Boot 5.4201
Western_Europe-Map v650.1127 |
Andy_P Pocket GPS Moderator
Posted: Tue Jul 24, 2007 1:05 am Post subject: |
You might need to tap "Show all menu options" in the menus, but it's definitely in the Main menu.
When you add points, you can choose "addresses" which then gives you "intersection" as one of the options, but yes you do need to know the cities. Or you can add waypoints by pointing to them on the map.
Or you can plot your exact route using MS Autoroute or even Google Maps or Google Earth and then convert them to an itinerary file you can load into the TomTom.
Use "Search" in this forum for details, they have all be discussed in the last few weeks. |
Posted: Tue Jul 24, 2007 2:36 am Post subject: |
Andy_P2002 wrote: | You might need to tap "Show all menu options" in the menus, but it's definitely in the Main menu. |
I found it. I had to hit "show all menu options" |
46jimbo Regular Visitor
Posted: Tue Jul 24, 2007 2:16 pm Post subject: |
When you make your itinerary, use the 'Point on map' method of placing your waypoints. You have to zoom in very close to make sure that you have set the point on the correct lane of a big highway. (If you set your point on the lane going in the opposite direction, the TomTom will make you go in circles!)
Once you have created the list of waypoints, highlight each one and make sure they are classed as 'Waypoints', and not 'Destination'. Only the final item in the list will be the 'Destination' (a checkered flag).
You can now save your itinerary and call it up whenever you wish to use it. Please note that in order to test it out, you must have a satellite lock. |
Posted: Tue Jul 24, 2007 11:05 pm Post subject: |
If I make an itinerary will it just give me directions from beginning to end (of trip) or will I have to tell it I was at the first stop and want to continue on to the next stop? |
sgould Frequent Visitor
Posted: Wed Jul 25, 2007 12:00 am Post subject: |
As long as you actually go through the waypoint you have chosen (or very near it), it will just send you to the next one. You don't have to do anything.
The important thing to remember is the zoom in to check that you are actually selecting a point on the road, and on the correct side of the road as well when there is a centre reservation (eg dual carriageway/ turnpike/freeway).
If you find an error after you have passed a waypoint, you can always select it and "mark as visited". But I've not had to do that lately. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Wed Jul 25, 2007 12:02 am Post subject: |
Just remembered. Once you have the Itinerary set up, you can run the GO in Demo Mode to check out the first 80 miles.
One final thing. You don't need to put your starting point in the Itinerary. The Go knows where you are and will send you straight to the first waypoint. _________________ TTGO 700 (dead)
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
