Pocket GPS World :: View topic - tom tom one data chk for 6.560
charlielucas
PostPosted: Sun Jun 24, 2007 8:13 pm    Post subject: tom tom one data chk for 6.560 Reply with quote
hi can someone please help i have downloaded all the voices for the speed cameras and put them in the map file but it still dont work, i need a updated data chk for my 6.560 to get them to work does antone have one please or tell me what else i can do ive tried the ogg files but still dont work. please help Sad
tom tom one app6.560
gps v1.21
map v675.1409
PostPosted: Sun Jun 24, 2007 8:19 pm    Post subject: Reply with quote
You need to use the ogg files as the data.chk method is not supported for that version of software, what have you done so far?
If the ogg files are in the map folder with the coresponding POI files AND you re-select EACH camera POI in the Change preferences/ Manage POI/ Warn when near POI it should work - have a read of the FAQ page #5 Here skip the first bit about data.chk and you should get it all working, if not how far do you get before it fails on you - Mike
charlielucas
PostPosted: Sun Jun 24, 2007 8:33 pm    Post subject: Reply with quote
hi mike thanks for getting back i think im a bit thick with this can you tell me if this is wrong the files show pocketgps_uk_gatso_30 bmp file
pocketgps_uk_gatso_30 ov2 file pocketgps_uk_ogg_30 file theses are all in the map. should there be in poi folder cos i dont have one.
PostPosted: Sun Jun 24, 2007 8:38 pm    Post subject: Reply with quote
ALL the POI files and the ogg files need to be in the map folder DO NOT put them in a seperate folder as this doesn't work.
Once the files are installed (which it sounds like you have done to be honest)
## Go to Change Preferences/ Manage POI/ Warn When near POI and from the list select the first Pocketgpsworld speed camera, answer NO if it asks you to remove the warning.
Allocate a distance for your warning
Select the Warn only if POI On route check box as per you preferences.
Repeat the above from the ## sign for EACH speed camera file you have installed - Mike
charlielucas
PostPosted: Sun Jun 24, 2007 8:47 pm    Post subject: Reply with quote
hi mike i done every thing you said up until it gets to the remove warning i taped no then it goes to warn when closer than 300 yards then i tap done then it goes to select warning sound and i still get the old polite1 sound. i cant understand where im going wrong.
regards charlie
PostPosted: Sun Jun 24, 2007 8:50 pm    Post subject: Reply with quote
charlielucas wrote:
pocketgps_uk_ogg_30
Is that how the OGG File is named?
If so there is your problem. It should have the same name as the OV2 File, but with an .ogg extension.
PostPosted: Sun Jun 24, 2007 8:53 pm    Post subject: Reply with quote
Which ogg sounds are you trying to use with the device? - it could be they are incorrectly named? - let me know which voice you are using and I assume from your previous post you are using the speed zoned database file set?
As another thought if its a PMobile camera that you are selecting there are no ogg files for these in most voice alert sets, so the device will still ask for a sound as the coresponding ogg file is not present - all the other cameras will work though - what is the name of the camera that you are seeing it request a sound for? - Mike
charlielucas
PostPosted: Sun Jun 24, 2007 8:54 pm    Post subject: Reply with quote
hi richard i read somewhere that the ogg file had to be changed to work so i changed it to work with the pocketgps cameras. where do i get the ogg file extentions from can you please show me how all 3 files should look. kind regards charlie
charlielucas
PostPosted: Sun Jun 24, 2007 8:58 pm    Post subject: Reply with quote
hi mike i got them off this website the single files i think can you tell me which one i need for my version. the camera i was using was gatso 30
charlielucas
PostPosted: Sun Jun 24, 2007 9:01 pm    Post subject: Reply with quote
hi can i use theses ones
We have changed the voices assigned to the current warning sounds to the following phrases (click on the phrase to listen to the sound sample - you need an OGG player for that):
Beep 1 Gatso
Beep 2 Gatso 30
Beep 3 Gatso 40
Beep 4 Gatso 50
Beep 5 Gatso 60
Bell 1 Mobile
Bell 2 Mobile 30
Bell 3 Mobile 40
Boing Mobile 50
Bugle Mobile 60
Cow Mobile 70
Cuckoo Red Light
Polite 1 Specs
Polite 2 Temporary
Polite 3 Credits
PostPosted: Sun Jun 24, 2007 9:08 pm    Post subject: Reply with quote
You need the ogg Files from http://www.pocketgpsworld.com/tomtom-ogg-files.php
The Files won't need renaming, just copying to the Map Folder.
When you use Warn When Near, you won't be asked for the Warning Selection if the ogg File has the correct name.
As Mike said they are all ready for the Speed Zoned Cameras. If you want to use the pMobile Files you will need a standard sound effect.
PostPosted: Sun Jun 24, 2007 9:12 pm    Post subject: Reply with quote
No you wont...
I did one set ("Crystal") for the pMobiles. It's at the bottom of the page.
If you want one of the other voices for them you can just make copies of the ordinary mobile ones and re-name to add the "P"
For the main voice sets, you can listen to the different voices just by clicking on them, pick the one you want, and they've all been re-named for you.
(and it was hard work too... Wink )
EDIT: As it looks like the pMobiles are here to stay, maybe I'll have to start thinking about adding them to the downloads for as many of the other sets as possible. Crying or Very sad
PostPosted: Sun Jun 24, 2007 9:14 pm    Post subject: Reply with quote
Sorry Andy. Embarassed
It's a long time since I've visited the page. ;)
charlielucas
hi richard how do i no which one to download in the first files ie single file, consolidated or speed zoned version. do i delete the old ones i have put on.ie ogg files
PostPosted: Sun Jun 24, 2007 9:30 pm    Post subject: Reply with quote
I would delete all the old ogg files and start again from scratch.
If you have the Speed Zoned Cameras, which you appear to have, you will need one of the Speed Zoned Voices.
There is a Sample File with each download, and you can hear this before you decide which download you want.
22.064 (26 Jun 24)
