Pocket GPS World :: View topic - Confirming data base is synchronised with my Garmin nuvi 310
Critty
PostPosted: Tue Jun 19, 2007 6:50 pm    Post subject: Confirming data base is synchronised with my Garmin nuvi 310 Reply with quote
I have subscribed and downloaded the latest data base to my computer.
How do I confirm that these file are successfully synchronised with my nuvi 310?
Regards , Chris
PostPosted: Wed Jun 20, 2007 1:41 pm    Post subject: Reply with quote
A good question.
When I copy the camera files to my TomTom, I always copy the "release.txt" file as well, so I can check the date inside if I forget where I'm up to with the new releases.
But to actually check if an update has worked, unless there's an easier way, maybe MaFt could put the ID number of one of the new cameras into the "release.txt" file, so you could quickly check for that one on your map, (assuming the Garmin has a POI "find" function like the TomToms).
Does that sound a good idea?
PaulB2005
PostPosted: Wed Jun 20, 2007 2:12 pm    Post subject: Reply with quote
Or you could just use POILoader to delete all POIs from the unit (the latest version gives you that option), confirm it's empty and then load the new POIs.
As POILoader confirms that the POIs have loaded ok i find that's enough for me.
22.071 (03 Jul 24)
