Pocket GPS World :: View topic - POI Icons are slightly wrapped!
jweaver
PostPosted: Wed May 23, 2007 3:21 pm    Post subject: POI Icons are slightly wrapped! Reply with quote
I am using TomTom 5.201 on my Palm and have recently borrowed/modified a set of POI icons for the speed camera database.
I have noticed that they are not quite right.. They are missing one pixel/column on the left side which is actually moved/wrapped to the right.
So, it looks a bit like this. Imagine the icon is ment to be a square:
What I see under TomTom is:
All my icons are 22x22 (Which I think is right) so doesn't anyone know whats wrong?
Jon
jweaver
PostPosted: Wed May 23, 2007 4:05 pm    Post subject: Reply with quote
I have done a bit of experimentation and found that if I reduce the file down to 21x21, 20x20 and 19x19 its exactly the same.
I also tried increasing the colour depth to 24bit, rather than 8bit and this has no effect.
But I have stumbled upon a workaround.. If I simply incease the file to 23x22 and left the left most column white, it appears normally..
If I was really clever, I could modify each BMP to put the right most columns on the left, so that when it 'wraps' it fixes the image.. But thats more complicated than leaving a blank line.
Am I the only one who has noticed this?
Jon
PostPosted: Wed May 23, 2007 5:38 pm    Post subject: Reply with quote
I have never seen this before, why not e-mail me the bmp files for the icons then I can take a look, (use the button below for my mail addr) - Mike
jweaver
PostPosted: Thu May 24, 2007 9:12 am    Post subject: Reply with quote
I will send you one straight way... But its really easy to reproduce.
I simply create a BMP of something like 20x20 (less or more gives the same results), and then draw a box 1 pixel wide around the ouside edge..
When I see it under TomTom, the left columns is missing, and the right side is 2 pixels thick, becaue the left most column has 'wrapped' to the right.
Jon
