Pocket GPS World :: View topic - Deleting Home and favourites
beth22
PostPosted: Thu May 10, 2007 10:34 am    Post subject: Deleting Home and favourites Reply with quote
I can't find a way to replace Home and delete selected favourites in the Garmin 3.2.
Holding down the centre button, with a favourite highlighted, brings up a delete option, but when I select it, and then say Yes to the confirm screen, they still aren't deleted.
Help please?
philpugh
PostPosted: Thu May 10, 2007 1:57 pm    Post subject: Reply with quote
Welcome Thumbs Up
What model are we talking about here? Is it a StreetPilot 320 or a nuvi 3xx - not too clear from the question?
For an SP320 then selecting a Favourite, as if making it a destination, then EDIT (lower RHS of screen) then delete should work. I don't believe there is a way of locking them to prevent accidental deletion - you have to go through enough screens as it is. Can you add to your favourites list?
To change your Home location you simply set it to another location - as you did originally. My Locations/Set Home then choose from the options as you require. There is no way to delete it (except perhaps setting the unit back to factory defaults - which may be an option of last resort here.
Come to think of it I believe a nuvi 3xx has a similar method of working with favourites. I haven't needed to change the Home Location on my wife's nuvi 310 - but it could be fun Laughing until she actually gets home. I believe this is different to the SP320 in that you edit the Home location much as you would any other Favourite.
If you are still having problems I would suggest you call GARMIN support - they are usually very helpful.
Phil
22.101 (03 Oct 24)
