Pocket GPS World :: View topic - Garmin Oregon & deleting caches.
danf1234
PostPosted: Thu Nov 06, 2008 4:39 pm    Post subject: Garmin Oregon & deleting caches. Reply with quote
This might be a daft question, but if you can't delete caches from the Oregon, what happens when you reach the maximum limit of 2000. How do you put fresh information of the GPS.
philpugh
PostPosted: Fri Nov 07, 2008 2:40 pm    Post subject: Reply with quote
The way to 'delete' geocaches is to remove the .GPX info you have on your Oregon that puts them there in the first place.
You can do this by manually editing the .GPX file (if it contains multiple entries) or by re-creating the .GPX using different selection criteria etc.
The beauty of the geocaching.com site is that you can run multiple searches based on (for example) different, small geographic areas. You can then have a 'cache' of .GPX files on your PC from which you can select the areas you are visiting. Don't forget to copy off the existing .GPX files as you mat have added information into it (e.g. cache found...)
Phil
22.055 (29 May 24)
