vladuna Occasional Visitor
![](modules/Forums/images/avatars/542644492463a619ae2572.jpg)
Joined: May 09, 2006 Posts: 3 Location: Crewe, Cheshire, UK
Posted: Thu May 03, 2007 5:18 am Post subject: Convert ozf2 |
Is there a way how to convert ozf2 + map files back to jpg/tiff/png + map files? thank you. |
barryd Frequent Visitor
Joined: Mar 27, 2004 Posts: 285 Location: Cheshire, England
Posted: Thu May 03, 2007 11:02 pm Post subject: |
Open the ozf map in OziExplorer on the PC then on the menu select File - Save Map to Image File - Colour Image. _________________ Barry Davies
Posted: Fri May 04, 2007 4:40 am Post subject: Calibrate again? |
Thank you, Barry. It works but it is necessary to calibrate BMP/PNG again, isn't it? ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Fri May 04, 2007 9:28 am Post subject: |
Yes, but it's easy enough just to copy across the calibration values from the original ozf map, isn't it? You could do either of the following:
1. Open the ozf map in OziExplorer then on the menu select "File - Check Calibration of Map" and note down the values. Use them to calibrate your new bmp map.
2. Open the ozf map file in Notepad, edit the second line to the name you want displayed for your map and the third line to the full path and filename of your bmp file, then Save As the new bmp map file.
