sugob Occasional Visitor
Posted: Sat Apr 28, 2007 2:05 pm Post subject: Want BT GPS receiver with same power connector as TomTom mk1 |
Currently using TT6 on Palm T3 with the original SiRF II TomTom bluetooth receiver that is getting a bit clapped out [battery life is a wee bit short]
www.pocketgpsworld.com/tomtombtgps.php
As I originally bought TT V4 for the Palm T3, it came with a mount that can charge both the T3 and the TT GPS receiver at the same time from the cigar lighter [so I only take this mount on holiday], would like a replacement GPS BT receiver that will take the same power connector [round, slightly smaller than that on a older Nokia phone] & voltage.
Can anyone confirm if the TT BT GBP II receiver has the same power connector as my version? Although it uses the improved SiRF III chipset, it has been out since at least Oct 2005 and if there are any other suggestions [similar size/weight, better sensitivity etc]...
www.pocketgpsworld.com/tomtom-bt-gps-mkii.php
TIA
M |
eillo7 Regular Visitor
Posted: Sat Apr 28, 2007 2:32 pm Post subject: |
I had a similar problem last year.
However, I didn't think choosing a new GPS receiver on the basis of its power connector to be particularly sensible. Instead I chose based on the merits of the receiver itself, and simply chopped off the old connector and soldered on a new one (mini-USB).
I am NOT proficient with electronics and have no knowledge or experience in this field - just a degree of common sense...oh, and a friend's soldering iron.
The power out on the Tomtom cradle is an RJ11 socket I think - depending on what you find as a new receiver you may be able to buy an RJ11 to XXX cable to suit your needs. |
Posted: Sun Apr 29, 2007 9:26 pm Post subject: |
Thanks for the reply but soldering small components was not what I had in mind 8O
I don't think choosing a GPS receiver this way is sensible either but I am willing to live with the compromise it means i.e. not necessarily getting the best available - however the Mk II doesn't seem that bad a receiver & an improvement from the mk I [which I have been happy with]
Looks like I'll get the TT mk II & if the power fitting is different then I may then follow your suggestion... |
alix776 Pocket GPS Moderator
![](modules/Forums/images/avatars/6212487444319be6786243.jpg)
Posted: Sun Apr 29, 2007 9:30 pm Post subject: |
the power connector is the same on the tt mk one and two receivers
bt if your in the market for a new receiver id go for perfomance and battery life _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
MrT Frequent Visitor
![](modules/Forums/images/avatars/gallery/065.gif)
Joined: Nov 14, 2003 Posts: 2143 Location: Surrounded by A1, M1 & M25
Posted: Mon Apr 30, 2007 4:09 pm Post subject: |
I use the same 5V charger for my Globalsat BT-338 and my iPAQ as my TT BT receiver. |
Darren Frequent Visitor
![](modules/Forums/images/avatars/gallery/dg-caricature-73x73.png)
Posted: Mon Apr 30, 2007 4:57 pm Post subject: |
TomTom's current BT GPS shares the same connector but most newer receivers use Mini-USB. The GlobalSat BT338 does use the same connector but this is an older model. _________________ Darren Griffin |
Posted: Mon Apr 30, 2007 9:56 pm Post subject: |
Thanks for the replies but I have now already ordered the TT mk II but handy to get confirmation about it's power connector [and an alternative].
Seems like there is not much in it between the GlobalSat BT338 and TT
One direct comparison from these fair forums
www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=17984&start=323
Cheers for the input
M |
jimbo_hippo Frequent Visitor
![](modules/Forums/images/avatars/21077135774339845938047.gif)
Posted: Tue May 01, 2007 11:06 am Post subject: |
One solution is to have a power socket fitted elsewhere. I fitted my old Holux GPSslim 236 in the other half's 5 series touring. The car's battery is in a compartment in the boot so now have a fused 12volt socket in there too and the GPS reciever is fixed flush to the vent grill at the top of the compartment and on 24/7. Bluetooth is strong enough to reach the front of the car and you can't see it so it's safe (black tape over the lights).
The great thing about this is no more dual power cords, swapping to charge either device mid journey, no waiting for a fix in central London etc and the other half doesn't have to worry about it. Just fire up the PDA and go. If you use another car I can just flip down the panel and remove the receiver (it's on velcro) and power cord ready for use elsewhere.
I had it fitted as part of a deal when a towbar was added but well worth it as a DIY or paid job.
Perhaps most importantly, when the car is empty and cradle removed there is no cables and evidence of GPS in the car.
I know this isn't a direct answer to the original question but thought I'd share as it might be a better solution to sourcing a splitter. Also, if the batterylife is the only issue and you're happy with the SirfII performance it might be better money spent to have it permanently on and sat-fixed rather than spend money on new reciever. _________________ Tom Tom GO 720
Orange M3100, Orange SPV M5000
TomTom Navigator 6, Destinator 6
Holux GPSslim |
Posted: Sun May 06, 2007 11:57 pm Post subject: |
Received the TT mk II receiver and seems to work pretty well - can now have receiver indoors about 10 foot from a window and still maintain a fix [TT shows about 20-30% signal strength].
The bonus is it also came with 4 adaptor cables to attach onto the TT power connector - one allows me to charge my Nokia 6280 [uses the newer 2mm Nokia power connector, rather than the older 3.5mm] and also one for mini usb connector.
I mainly use TT in hired cars [US/Europe] so permanent fixing is not an option - infact it was the use of the 'NeverLost' in a Hertz car a few times that showed me the usefulness of GPS [even though it looks ultra primitive now (last time I looked, it still looked exactly the same as 5+ years ago)]
Thanks for all your help/suggestions
M |
