Pocket GPS World :: View topic - POI Edit problem
POI Edit problem
glenn
PostPosted: Tue Jan 20, 2004 12:06 pm    Post subject: POI Edit problem Reply with quote
Have downloaded and installed POI Edit.
When I run Autoupdate wizard I get error message:
Cannot retrieve proxy settings. Probably these are set to Auto Detect or Auto Configuration.
You can set proxy settings manually from the Online / Proxy settings menu.
Where and how do I set the proxy settings?
PostPosted: Tue Jan 20, 2004 7:24 pm    Post subject: Reply with quote
Check the FAQ this should sort your problem unless you're behind a proxy server in which you'll need to talk to your System Administrator.
glenn
PostPosted: Wed Jan 21, 2004 5:13 pm    Post subject: Reply with quote
:P
Thanks. That worked just fine.
22.101 (03 Oct 24)
