Pocket GPS World :: View topic - magellan gps pioneer
Alan18
PostPosted: Fri Apr 13, 2007 12:42 pm    Post subject: magellan gps pioneer Reply with quote
I have bought one of the above (yes I know it's old but hopefully it will do what I want) Everything looks fine apart from when It comes to getting a fix the most it will pick up is one satellite. It shows up to eight but will only track one. I'm confidant that I have set it up correctly so have any of you knowledgeable people a solution.
Thanks in advance,
Alan
philpugh
PostPosted: Fri Apr 13, 2007 1:58 pm    Post subject: Reply with quote
Make sure you are outside with clear views of the horizon for 360 degs.
Turn on the unit and leave it alone for a while (could be as much as 45 mins)
This is quite normal behaviour for a GPS unit that has been off a very long time or has been moved a very long way around the world whilst off.
If it still hasn't got a lock - it may not be working correctly.
Don't move it while it is getting a lock - this tends to increase the lock time.
Once it has gone through this procedure - if you use it reasonably often - it should only take from seconds to la couple of mins to get fix depending on how long it's been off and if it has moved some distance whilst being off.
Phil
22.071 (03 Jul 24)
