Pocket GPS World :: View topic - Which file to download for Speed cameras
RoystonB
PostPosted: Wed Apr 04, 2007 9:54 am    Post subject: Which file to download for Speed cameras Reply with quote
I had a look at the speed camera download table, but can't decide which file to download. Embarassed
I have a Go710.
Do I download the Go910 or the Go Series?
Many thanks in advance. Laughing
PostPosted: Wed Apr 04, 2007 10:29 am    Post subject: Reply with quote
If you have been looking at the big green and red compatibity table, the ONLY reason that the 910 is listed seperately is because the instructions are slightly different - the actual downloads are exactly the same.
When you get to the download page, the options for ALL TomToms are the "ov2" version or the "Home" version.
If you are confident with moving files around on your PC by normal copying and pasting then the "ov2" method is easier and gives you a better idea of the principles involved (you'll also find that if it all goes wrong, people on here who can help are more likely to understand that way of doing it!
Your other choice to make is whether to go for the single file, the split up by camera type (or "consolidated by type" as they call it), or the speed-zoned set.
This is up to you... the single file is easiest to install ('cos there's only one file!) but the speed-zoned set gives you the most information and is generally considered the best because you get on-screen (and optionally spoken) warnings of the speed limit in force at each camera.
Good luck, follow the instructions very carefully, it is actually very simple, but, like all computer stuff there are plenty of pitfalls if you miss an instruction.
Come back if you have any more questions/ problems.
22.094 (25 Sep 24)
