darlyn Occasional Visitor
Posted: Wed Jan 10, 2007 11:44 pm Post subject: acer n35 |
i have a acer n35 an want t use it in my lorry but cant get the charger to work when i put on it lock up when it in the 12v cig lighter in lorry i know it is 12v iput it in my self as i only had 24v in lorry |
theripper Pocket GPS Verifier
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Joined: Feb 07, 2006 Posts: 581 Location: Medway Towns, Kent
Posted: Thu Jan 11, 2007 1:16 am Post subject: |
I think you will find that the charger supplied with the N35 is 12/24 volt
Mine was
theripper |
buster0007 Occasional Visitor
Posted: Sat Jan 13, 2007 2:21 pm Post subject: |
Hi I see you are running tt with the acer n35 I also have a n35 but it cant find the gps I have tried all the settings on all the comm. Ports and still it wont find the gps can you tell me if you have a driver or a utility on your n35 to allow it to work many thanks |
Brian566 Occasional Visitor
Posted: Sat Jan 13, 2007 10:30 pm Post subject: acer n35 |
I think all acer n35 have this problem i could understand it if it had poor signal but not GPS not found
I think its aproblem with when you shut down programd Min can be up to 50 minutes before signal or never
But if you do a soft reset it should find GPS in 10 minutes this seem to re start it
But it is a poor unit for GPS signal |
Posted: Sun Jan 14, 2007 12:20 am Post subject: |
Hi thanks for the reply but it does not start to look for satellites the red and black circle does not turn on any settings this is why I was asking if it needs a driver or utility the blue light does flash though if I look in programs or settings there is nothing in there to set up please help |
Pc-Mobile Frequent Visitor
![](http://www.pocketgpsworld.com/blank.gif)
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Sun Jan 14, 2007 2:39 am Post subject: |
This is what happens with Navman Pin570 and it may be the same with n35:
Every time you turn off the PDA and on again you have to turn on the GPS in the setting.
See if that is your problem. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Posted: Sun Jan 14, 2007 11:51 am Post subject: |
That’s just it there is no setting to switch it on and off just the settings in TT and I have gone through every one of them. But the GPS light comes on as soon as you flip it open with it being built in should I have a driver or utility in the PDA menu |
Nielsdad Occasional Visitor
Posted: Thu Mar 15, 2007 11:57 pm Post subject: |
Sorry to hear about your trouble. I've been running TT6 on my N35 for a while now and I have had no trouble finding a GPS signal. My settings are:
other NMEA GPS receiver,
baud rate 9600
GPS ON NAVIGATOR
After a few seconds it usually starts searching for about 8 satelites. I have no other software running to make this happen.
As far as I can find there is no direct way to control the built in GPS under settings. |
