BONDENO Occasional Visitor
Posted: Fri Mar 09, 2007 5:04 pm Post subject: Urgent help please tom tom 1 need for tonight |
Hi Thanks for trying to help me out.Just switched tom tom 1 on the screen comes on reading memory card then i get just the tom tom screen with the 2 red hands,No map cant switch off either unless i reset,Gone for reset and reset pressing in for 10 seconds,Any ideas please |
Posted: Fri Mar 09, 2007 5:08 pm Post subject: |
Reset for 30 seconds with a pin, then see what happens - how was the device when you last used it? and have you added anything to it (POI, software updates etc) - Mike |
Posted: Fri Mar 09, 2007 5:24 pm Post subject: |
Hi Mike
Thanks for trying to help,Yes poi added but been fine since adding them over twelve months ago.Tried reset button loads of time 30 seconds plus.
Phil |
RQ Regular Visitor
Posted: Fri Mar 09, 2007 5:36 pm Post subject: |
Did you make a backup that you could use? |
Posted: Fri Mar 09, 2007 5:44 pm Post subject: |
Just tring that mike will let u know |
Joined: 30/12/2002 17:36:20 Posts: 4912 Location: Oxfordshire, England, UK
Posted: Fri Mar 09, 2007 5:51 pm Post subject: |
If nothing else works, take out and then put back SD card whilst unit is switched off. Then switch unit on.
Garmin Camper 770 LMT-D |
Posted: Fri Mar 09, 2007 6:12 pm Post subject: |
H Guys
Just put back up on sd card all seems to be ok ,I hope its stays ok,
Thanks for your time time guys
Cheers :D |
Andy_P Pocket GPS Moderator
Posted: Fri Mar 09, 2007 11:28 pm Post subject: |
Brilliant. Well done for having a backup.
Saves SO much aggro! |
theripper Pocket GPS Verifier
Joined: Feb 07, 2006 Posts: 581 Location: Medway Towns, Kent
Posted: Sat Mar 10, 2007 2:33 am Post subject: |
Hi Bondeno
Just had the same problem updating software on a friends ONE, seems that the problem was upgrading two jumps so to speak. Reinstalled the backup then did one upgrade at a time and everything was ok
theripper |
