Pocket GPS World :: View topic - NAVMAN ICN520
NAVMAN ICN520
xplociv
PostPosted: Sun Feb 25, 2007 11:00 am    Post subject: NAVMAN ICN520 Reply with quote
hey i updated my icn520 wif a navman icn 510 updater accicdnelty and my maps wont load they are highlighted in red i tried the method wif smartst desktop from another post but that still didnt help. Is their a way to reset my navman to original factory settings so my icn520 software will return ??? or a way to reset for that to ahppen? plz reply asap
thank you Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
Gee-Pee
PostPosted: Sun Feb 25, 2007 11:52 am    Post subject: Re: HELP PLZZZZZZZZZ NAVMAN ICN520 PLZ HELPPPPPPPPPPPPPPP Reply with quote
See this thread HERE
Hold down the HOME key and reset the device when prompted by ticking 'Yes'.
Gee-Pee
xplociv
PostPosted: Sun Feb 25, 2007 12:05 pm    Post subject: gee-pee reply asap Reply with quote
Gee-pee thanx for ur reply but this did not remove the icn510 software from my icn520 so it still thinks it is a icn510 and still does not load my maps they are still highlighted in red. do u know where i culd obtain teh icn 520 updater?? or would a hard reset cure this problem thanx mate
Gee-Pee
PostPosted: Sun Feb 25, 2007 12:49 pm    Post subject: Re: gee-pee reply asap Reply with quote
Open your SmartST desktop programme and then connect your Navman. Now click on the 'Check for Updates' tab.
Yes, you could try a hard reset. Just turn the Power switch off on the back then on again and you should have to go through the 'Accept Agreement' process and the maps will then re-load.
Gee-Pee
DRP
PostPosted: Sun Feb 25, 2007 3:18 pm    Post subject: Reply with quote
If what Gee Pee said did not work, goto page 69 of the manual, do an uninstall, then reinstall your software, then do not forget to get your registration. this can be found under tools, manual found under help of your desk top software.
Regards
DRP
Sharing information is the key to a better understanding
Mio M400 WEU, N60I, T1, 2x B2, iCN 510 & lots more
xplociv
PostPosted: Sun Feb 25, 2007 10:57 pm    Post subject: Reply with quote
hey neither of those worked becasue wen i try to update wif my smartst desktop i click yes all that happens is it says please wait and then it minimizes and maximises wif no change to the navman ? it also saysy smartst is not installed on your navman qwould u liek to install it i cklick yes and the same thing happens. when i try to recover my registration details it doesnt connect to the net im using smartst desktop v3
?? everything on my gps works but the maps??
plz help i think i need an updater to use straight on my icn520 cause atm it says its an icn510
DRP
PostPosted: Mon Feb 26, 2007 1:06 am    Post subject: Reply with quote
Have you tried my sugestions?
If you follow them you should not go wrong.
Have you installed SmartST on your PC? Is it installed correctly.
Regards
DRP
mostdom
PostPosted: Mon Feb 26, 2007 1:14 am    Post subject: Reply with quote
I believe that the updater on smartdesk only updates the device with the last downloaded update. In your case the 510. I think you may find the 520 software on the original disks.
I remember doing this once or twice on my old 5 series GPS, but don't exactly remember how. Confused
Dom
jetskidia
PostPosted: Sun Nov 25, 2007 5:37 pm    Post subject: Reply with quote
After I hard reset my Navman 520 the only voices I could get were uSA ones???
How do I get the UK ones back?
Gee-Pee
PostPosted: Sun Nov 25, 2007 6:24 pm    Post subject: Reply with quote
Chapter 20, page 84 explains how to reinstall the English language on your iCN5** device. Remember, if you have not got a copy its easy enough to download a pdf version. Wink
I seem to remember this was a very common problem that members experienced some time ago when there was a patch issued by Navman.
Gee-Pee
22.071 (03 Jul 24)
