harry1968 Occasional Visitor
Posted: Thu Feb 22, 2007 8:42 pm Post subject: Garmin 310D refresh rate |
My 310D maps seem to refresh slowy ie when I pass a street, the 310 will show me passing the street several hundred feet later. Ive set mapping detail to least in settings but its still the same? |
philpugh Lifetime Member
![](modules/Forums/images/avatars/gallery/bass_fret.jpg)
Joined: Dec 28, 2005 Posts: 2003 Location: Antrobus, Cheshire
Posted: Fri Feb 23, 2007 1:31 pm Post subject: |
Are you following a route when this happens?
I notice this if I just have the map on - but no route - on my 660. I think it's to do with the way they handle junctions. Because of the 'lock to centre line of road' it 'waits' to get a good fix on which road you have taken. Garmin seem to have opted for a safe approach to this which delays the update by a few seconds under these conditions. I haven't seen it when navigating a route (it assumes you are still following it!)
I guess if you have no route the assumption is that you know where you are going. _________________ Phil |
mostdom Pocket GPS Moderator
![](modules/Forums/images/avatars/20941253924f0d8a4db1041.jpg)
Joined: Jul 10, 2006 Posts: 1964 Location: Surrey, UK.
Posted: Fri Feb 23, 2007 1:52 pm Post subject: |
Could also be an out of sync section of map. Although these devices lock to the roads if the map is out by only a small amount the GPS device will continue to try to put you in the field ajacent to you.
It can't abviously do this as i must stick to the roads, but when a side road passes it will look to jump to its real location.
When it does this you will have already passed the road, and it will have to recalculate itself again.
Found this on my Navman in a few places.Very annoying on motorways when it can jump you completly off the motorway. ![Sad](modules/Forums/images/smiles/icon_sad.gif) _________________ Dom
Navigon 7310/iPhone Navigon&Copilot |
swing Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Fri Feb 23, 2007 5:55 pm Post subject: |
I'm with philpugh on this one - the only time I've ever noticed lag on my 310D was one day when I didn't have a route planned. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
