Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Sat Nov 06, 2004 4:06 pm Post subject: Adding Safety Camera Support to Navman Products |
Since the October release of the Safety Cameras, instructions have now changed for Navman users running V3 software which includes the V3 software itself (not yet released), iCN510, iCN635 and iCN650.
These instructions can be found here. |
breers Occasional Visitor
Posted: Sat Nov 20, 2004 12:46 pm Post subject: |
thank you for this information dave - most useful, but a little frustrating for me. i am a complete novice at this and am having a little trouble downloading - can i ask you to read my postings on spped camera database and advise if at all possible.
steven (breers) |
Spider-101 Occasional Visitor
Posted: Mon Dec 13, 2004 3:32 pm Post subject: |
I've looked at the instructions and one thing puzzles me, what does the Navman "say" as the audible warning? I can see were you put in the bmp file that gives the symbol for a camera, but I would have expected a wav or something for the audio alarm, or am I missing something.
thanks |
Posted: Mon Dec 13, 2004 3:44 pm Post subject: |
Sorry, just seen the answer to my own question, its an audible chime, not a verbal warning |
Gee-Pee Lifetime Member
![](modules/Forums/images/avatars/2753245604985889cd11f6.jpg)
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Fri Feb 11, 2005 2:27 pm Post subject: Navman POIs |
Dave, Just downloaded the latest Speed Camera database - POIs and installed.
In the download, there is another folder with .wav files for audio speed limits, warnings of approach to cams etc. etc.
Can I intall/use these on my Navman iCN510 If so, how do I do so. At the moment, all that I have installed is those files NOT in the speed zoned folder.
Graham-P |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Fri Feb 11, 2005 2:42 pm Post subject: |
You cannot use the warning sounds, unfortunately. The SmartST V3 software only allows for one sound to be played for all the Custom POIs.
You can, however, use the speedzoned .csv files and associate them with their own .bmp files. If you do this, first remove the Mobile and Gatso POIs, or you will have the information duplicated. _________________ Tim |
Posted: Fri Feb 11, 2005 3:17 pm Post subject: Audio warning |
Thanks for prompt response, Tim. Will accept the present set-up as it is more than adequate for my needs.
Gee-Pee :D |
Boilerman Occasional Visitor
![](modules/Forums/images/avatars/gallery/077.gif)
Posted: Sun Mar 20, 2005 1:12 pm Post subject: Just when I thought I had done it! |
Upon following all the instructions for loading the Gatso sites onto my 510 I get the following message. NO POI'S FOUND IN INPUT FILE. Anybody have any ideas on what to do next? ![Evil or Very Mad](modules/Forums/images/smiles/icon_evil.gif) |
Posted: Sun Mar 20, 2005 1:41 pm Post subject: |
Reread the instructions! If it doesn't work by following the instuctions to the letter, it's possible that the download has been corrupted. _________________ Tim |
ShirleyTemple Regular Visitor
![](modules/Forums/images/avatars/39660440245fe9ac1e9aa4.jpg)
Joined: Feb 11, 2005 Posts: 141 Location: Southampton/Portsmouth
Posted: Sun Mar 20, 2005 7:07 pm Post subject: |
I've just loaded the same Gatso data into my 510 following the afore mentioned instructions and it went without any problems and it was all Greek to me. Still is!!! |
Posted: Sun Apr 17, 2005 11:56 am Post subject: Updating POI's |
Erroneiously posted this in the 510 forum. Could you help?
Great service but in the instructions this month, it says only use the csv files for the Navman whereas I've always included the bmp files in my install. Could someone clarify, please.
FTB I have also installed the appropriate bmp files but wondered if it is only necessary to update the csv files on the assumption that the 'old' bmp files remain active. _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
104456 Occasional Visitor
Posted: Sat May 07, 2005 10:01 pm Post subject: |
To the latter question yes you should just update the csv file and it will use the same bitmap.
On a side note I notice if you look at the ini files relating to these POIs there is a default sound set so this would suggest putting the relavent sound file within the windows folder and ammending the last line of the ini file would produce individual sounds for each type of camera encountered. |
Posted: Sat May 07, 2005 10:06 pm Post subject: |
Forgot to mention,if the database were split into speed zones it should be possible to play a different speed warning for each too i.e. "warning 30 mile speed limit" |
jabber Occasional Visitor
Posted: Sun May 08, 2005 2:33 am Post subject: |
oh boy im so confused, this is all new to me . i have tried and tried to follow the instructions and i dare say they are easy enough, well not for me i get the message no poi found on input file. infact i dont even think i;m saving it correctly from the download site. Please please help me and explain it all in ultra idiot form, do i save it in excel ? and then there is csv. bmp etc etc, i would be very grateful. yep i need step 1 to end and what i should e seeing with no tech talk.
Thankyou angela |
Posted: Sun May 08, 2005 6:41 am Post subject: |
jabber wrote: | oh boy im so confused, this is all new to me . i have tried and tried to follow the instructions and i dare say they are easy enough, well not for me i get the message no poi found on input file. infact i dont even think i;m saving it correctly from the download site. Please please help me and explain it all in ultra idiot form, do i save it in excel ? and then there is csv. bmp etc etc, i would be very grateful. yep i need step 1 to end and what i should e seeing with no tech talk.
Thankyou angela |
If you have downloaded the full instructions - see Dave's post at the beginning of this thread, then you should be able to load the POI's on your Navman. Remember, there are only six individual csv files to load plus the appropriate bmp files (the speed camera icons) OR the simplest way is to use the single combined Zip file which contains everything.
![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) _________________ Gee-Pee
