Pocket GPS World :: View topic - Bluetooth Pairing Problem
opt2mst
PostPosted: Wed Jan 31, 2007 8:22 pm    Post subject: Bluetooth Pairing Problem Reply with quote
I have an issue pairing a Go710 with my Nokia 6230i and hope someone can help. I can pair the devices fine except that everytime I need to re-enter the passcode. Can someone advise how to automate this process.
The settings are identical for this device as they are for my Hands free Bluetooth carkit which works just fine and does not require the passcode each time.
PostPosted: Wed Jan 31, 2007 9:58 pm    Post subject: Reply with quote
Welcome
Only thing I can think of is you need to ensure your 6230i allows itself to be seen by all. I have the same setup as you with no problems.
opt2mst
PostPosted: Thu Feb 01, 2007 8:16 am    Post subject: Reply with quote
Thanks for your reply. I can confirm that I have my phone set to "Seen by all" I suspect that I would not be able to even see the phone if this was not the case.
As I mentioned I can pair devices without any problem. The issue is that each time that I turn on the GPS I am prompted to enter a passcode to establish the pairing.
PostPosted: Thu Feb 01, 2007 8:56 am    Post subject: Reply with quote
So sorry. My 710 has Bluetooth enabled and when I switch it on (my phone is never switched off), it just blinks and says "connected to Nokia 6230i". It just does it - magic, new technology, whatever. I don't know how I've done it! Back in my youth I used to shout at a tin can with string, it's all different now. The only other thing I know is if any other bluetooth thingy is already connected, it won't pick up a second one - I have a GO700 also paired and whichever gets switched on first gets connected and the other doesn't - I don't suppose that helps at all!
alan_dr
PostPosted: Thu Feb 01, 2007 3:30 pm    Post subject: Reply with quote
In bluetooth settings, paired devices, devicename, options, theres a setting auto-connect without confirmation. Set it to yes. That may do it.
Alan - iPhone 5 64GB, with CamerAlert, TomTom Europe & CoPilot
opt2mst
PostPosted: Thu Feb 01, 2007 8:01 pm    Post subject: Reply with quote
I have the auto-connect without confirmation set to yes. Any other ideas ?
LT
PostPosted: Thu Feb 01, 2007 9:04 pm    Post subject: Reply with quote
I have a Go 510 and the device will pair with my SE W800i straightaway in phone mode. For the traffic alerts it was a different matter and it always had to ask. That was until I updated the device when I got a RDS TMC thingy. After that it seemed to pair straightaway for the traffic.
I've just updated the software again, and guess what? It now starts to ask again! Crying or Very sad
entwood
PostPosted: Thu Feb 01, 2007 9:34 pm    Post subject: Reply with quote
I have a nokia 5500 and TT700 which pair just fine but initially I had the same problem .... reading the manual I found that under the TT700 link / proprties was the option to set "as authorised" .. once done it then connects up fine.. without needing authorisation .. just as it says on the tin ... Smile
hope this helps
opt2mst
PostPosted: Fri Feb 16, 2007 2:12 pm    Post subject: Update on this issue Reply with quote
I submitted a fault directly to Tomtom and finally received a reply. I have not tested the process to see if it resolves this issue but thought I would post the link in case it assists someone else check out the link - http://service.tomtom.com/cgi-bin/uk.cfg/php/enduser/std_adp.php?p_faqid=6187&p_created=1158057306
22.064 (26 Jun 24)
