Pocket GPS World :: View topic - Speed Cameras on 910
marshy18
PostPosted: Sat Jan 27, 2007 4:43 pm    Post subject: Speed Cameras on 910 Reply with quote
I've just loaded the pgps speed cameras onto my tomtom 910 and all seems to be working fine along with the text - speech files.
Can someone advise if there is a way of making the camera locations only available in the direction of travel and not announced when on the opposite side of the carriageway?
Also is there a built in amp for running an external speaker?
PostPosted: Sat Jan 27, 2007 6:16 pm    Post subject: Reply with quote
1) No, in common with nearly all other satnavs, the TomTom only sees a camera or any other POI as a "point on the map", there is no direction information (only the latest Mio units can do this AFAIK).
The only time you won't get a warning is on dual carriageways. These are seen by the TT as two seperate routes, so assuming you have "Warn only when on route" ticked in the setup for each camera type it will ignore the one one the other carriageway.
2)There is no built in amp, but you can get the audio out to run into an external amp and speaker.
22.063 (19 Jun 24)
