portman Frequent Visitor
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Fri Jan 26, 2007 6:10 pm Post subject: |
The only warning I would give is that I believe they are possibly selling the Kenwood GTM10, and not the Garmin GTM10. Although it's the same device, the Garmin version comes with more aerial converter connectors, which may be an issue to some. Obtaining these converter cables is not easy. |
Posted: Sat Jan 27, 2007 12:25 pm Post subject: |
portman wrote: | The car aerial adapters can be found easily for £3-4 each so max £8. | Where can you get the Garmin Fakra connector for £3-4 from please? |
Posted: Sat Jan 27, 2007 4:51 pm Post subject: |
Good finds there!
However, that only covers the ISO and the DIN connectors that Garmin would have put in the box. Anyone with a Fakra car aerial (All VAG cars - Audi, VW, Seat, Skoda) still can't connect the stereo.
However, you are right that the adaptors are out there for the majority of cars. |
Posted: Sat Jan 27, 2007 7:30 pm Post subject: |
Is this a test?
Not sure what a VW one would look like, but whether you bought the Garmin or the Kenwood one you'd still need an adapter, can't be more than £15. _________________ Samsung Mega
Tomtom 500
Posted: Sat Jan 27, 2007 8:51 pm Post subject: |
No, it's not a test, I'm simply informing you of the situation (and anyone else reading this thread).
As I've said, the VAG range use a Fakra car aerial connector - if you buy the Garmin GTM10, the connector for that (and 2 other car aerial types are included in the box) - if you buy the Kenwood GTM10, you only get 1 type of car aerial connector. Fakra connectors are nigh on impossible to obtain (as are adaptor cables for Fakra) and hence people need to be aware of the differences between the two models before assuming that these companies are selling the same device as listed on the Garmin website. |
Posted: Sat Jan 27, 2007 10:53 pm Post subject: |
I presume the end of the VW antenna lead has a fakra connector that goes straight in to the GTM 10. If this is the case just connect up the two din/iso leads supplied to make a double ended fakra lead to plug into the stereo. _________________ Samsung Mega
Tomtom 500
Posted: Sun Jan 28, 2007 12:30 pm Post subject: |
Oh, nice idea! |
locksmith Lifetime Member
tkerby Lifetime Member
Posted: Wed Jan 31, 2007 2:27 pm Post subject: |
Only problem I see with these is the stereo must be turned on if you have a retractable aerial  |
Posted: Wed Jan 31, 2007 3:51 pm Post subject: |
locksmith wrote: | Just to get this clear in my mind. Will this GTM 10 work with my Nuvi310 and connect into my Vivaro van radio? | It should work if your Vivaro has the same aerial connector as shown in the picture, although please don't blame me if it doesn't work. |
Posted: Wed Jan 31, 2007 4:05 pm Post subject: |
If the end of your Vivaro antenna lead has a 'female' fakra connector on it, it will connect straight in to the GTM 10. If it has a din or iso connector you just have to use the connectors suppied with the GTM 10.
The female fakra connector is on the far left, the iso/din are the two on the right.
http://www.incarexpress.co.uk/catimages/accs/pc5111.jpg _________________ Samsung Mega
Tomtom 500
