mort66 Occasional Visitor
Posted: Mon Jan 22, 2007 7:37 pm Post subject: tomtom 300 big problem |
hi all, my tomtom 300 is playing up. when i power up it needs speed cam poi resetting and it wont store my home settings anyone else had this ? |
Posted: Mon Jan 22, 2007 7:52 pm Post subject: |
Has the write/ lock switch on the memory card been accidentally pushed to the wrong setting i.e. LOCK, if so switch it to the other position to un-lock it and try again - Mike |
Posted: Mon Jan 22, 2007 8:38 pm Post subject: thanks but ? |
how do i sort it. is it the reset button near the w/screen mount |
Posted: Mon Jan 22, 2007 8:50 pm Post subject: found it |
found it but still no good |
Oldboy Pocket GPS Moderator
Posted: Tue Jan 23, 2007 7:59 am Post subject: Re: thanks but ? |
mort66 wrote: | how do i sort it. is it the reset button near the w/screen mount | Not the Reset Button.
mikealder wrote: | the write/ lock switch on the memory card |
_________________ Richard
Andy_P Pocket GPS Moderator
Posted: Tue Jan 23, 2007 2:19 pm Post subject: |
You could also try checking to see if the .cfg file in your map folder (either called Map_Settings.cfg or {mapname}.cfg) has been accidentally switched to "read only"
Do this by connecting the Go to the PC and using Windows Explorer (not Internet Explorer) to find the file in your Go's map folder. Right click on the file and select "properties". Check there is NO tick in the "read only" box at the bottom. If there was, remove it and click "Apply".
To be honest, I don't know if the Linux-based Go will take any notice of this setting, but it's probably worth a try. |
