Pocket GPS World :: View topic - Holux CF card problem on PocketPC
quiche
PostPosted: Thu Aug 17, 2006 10:36 pm    Post subject: Holux CF card problem on PocketPC Reply with quote
I have a Holux GPS receiver CF card and tried it today on my Jornada 547 PocketPC 2000. I have the Holux software installed on the Jornada and through the software turned the GPS on and started receiving on COM port 2.
I also have Pocket Streets 2005 installed with a map of my local area. I pull up the Pocket Streets and it did not see that the GPS card was on and receiving. When I pulled up the menu for Configuring the GPS receiver - it said it received on COM ports 1, 3, 4 and 9. There is no way to change the COM port settings with either the Holux software nor on Pocket Streets (or I couldn't find a way to change these settings).
What do I need to do?
dlyall
PostPosted: Mon Jan 08, 2007 1:18 pm    Post subject: Reply with quote
When you say Holux software installed, do you mean the GPS Viewer? If so, did you close the GPS and completely exit from that before trying Pocket Streets?
If the COM port is open by GPS Viewer you won't be able to connect to the GPS with any other software
HTH
22.055 (29 May 24)
