Pocket GPS World :: View topic - Garmin i3 Micro SD
Garmin i3 Micro SD
bmgreaves
PostPosted: Wed Dec 13, 2006 9:56 am    Post subject: Garmin i3 Micro SD Reply with quote
I got fed up of receiving the Error Message 'not enough room on your GPS to accept all the POIs' - So I bought a 512MB Micro SD Card. I then downloaded the POI files (Complete) and the Speed Camera database onto the new Micro SD Card and installed it into my i3. It appears that it has not been accepted by the i3. Do I have to do something more? I still get the same error message when I try to download POI & Camera Updates onto the i3 - I have left the Micro SD installed into the SD Slot on the i3.
Somebody please help.
bmgreaves
PostPosted: Wed Dec 13, 2006 10:12 am    Post subject: Re: Garmin i3 Micro SD Reply with quote
swanson2
PostPosted: Wed Dec 13, 2006 11:16 am    Post subject: i3 POI's Reply with quote
Hi bmgreaves,
You have to load the POI's and Speed Camera locations on to your SD card using the Garmin POI download software.
To do this try the following:-
Slot your SD card into a card reader and plug the card reader into a USB port on your PC.
Then open the Garmin POI downloader and it will recognise your SD card.
You then download the data to your SD card the same as you would if your i3 was plugged in.
Finally slot the i3 card back into the i3 and all should work OK.
Hope this helps you?
Robert Swanson :D
I have enjoyed the past, but my main interest is in the future, because I am going to spend the rest of my life there!
swanson2
PostPosted: Wed Dec 13, 2006 11:25 am    Post subject: Re: i3 POI's Reply with quote
Hi bmgreaves,
In my previous message to you the last line of instructions should have read :-
Finally slot the SD card back into the i3 and all should work OK.
Robert Swanson
:D
22.064 (26 Jun 24)
