Pocket GPS World :: View topic - POI Icons
POI Icons
danny_leeuk2
PostPosted: Sat Dec 02, 2006 6:13 pm    Post subject: POI Icons Reply with quote
Does anyone know how to get the unit to show all icons as you keep the map in view mode as you drive.
I have got icons for all my POIs but only show in the unit when you do a location preview.
equalizr
PostPosted: Sun Dec 03, 2006 3:47 am    Post subject: Reply with quote
which unit do you have? I have the c330 and it shows nothing unless i go and view the map
danny_leeuk2
PostPosted: Sun Dec 03, 2006 5:25 pm    Post subject: Reply with quote
Street i3
PaulB2005
PostPosted: Sun Dec 03, 2006 8:57 pm    Post subject: Reply with quote
Garmin i3 = you can't.
PaulB2005
PostPosted: Mon Dec 04, 2006 1:21 am    Post subject: Reply with quote
Well you can by setting the proximity alerts for all the POIs using POILoader but the constant bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, bong, wherever you go gets annoying after 15 seconds...
zogman
PostPosted: Mon Dec 04, 2006 9:54 am    Post subject: Reply with quote
paul...sounds like you've gone 'bong kers'. Laughing
Lester_Burnham
PostPosted: Mon Dec 04, 2006 2:52 pm    Post subject: Reply with quote
You could turn off attention tones, though.
What happens if you turn of proximity alerts - does it just disable the audio, or does it no longer show you the POI?
PaulB2005
PostPosted: Mon Dec 04, 2006 3:06 pm    Post subject: Reply with quote
Turns off both as it's just the Alert and not just the tone it controls. I turned the Proximity Alerts off once and no cameras showed up. Turned it back on quickly!!!
I have played with the settings in the i3 and can't get it to show POIs without using over speed or proximity warnings and it gets very annoying.
Lester_Burnham
PostPosted: Mon Dec 04, 2006 3:08 pm    Post subject: Reply with quote
Well if you've got the "right" kind of i3, you could always edit the voice files to blank out the offending one...
mars.1
PostPosted: Mon Dec 04, 2006 3:44 pm    Post subject: Reply with quote
You can get the icons for the speed cameras to show at all times on the i3,just by tweaking the csv files.
paulyoung666
PostPosted: Mon Dec 04, 2006 9:38 pm    Post subject: Reply with quote
would you care to share the info then :D
mars.1
PostPosted: Tue Dec 05, 2006 12:43 am    Post subject: Reply with quote
Go into the speed camera csv file then hold down [ctrl + h] at the same time.A box should come up, then at the top enter @50 for the speed, then below it press the space bar 2 times and then enter just the same speed which you did at the top and not the @.Hit the replace all button in the box and when its finished do the same for the other speed catergories and different camera types.
danny_leeuk2
PostPosted: Tue Dec 05, 2006 7:04 am    Post subject: Reply with quote
Sad couldnt get this to work
PaulB2005
PostPosted: Tue Dec 05, 2006 8:28 am    Post subject: Reply with quote
USE Ash10's Camera Manager http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=43111 instead. Much easier
22.064 (26 Jun 24)
