Pocket GPS World :: View topic - Haicom 403 BT Cube
Haicom 403 BT Cube
Ixtana_ran
PostPosted: Sat Dec 02, 2006 10:52 am    Post subject: Haicom 403 BT Cube Reply with quote
Could any one tell me the correct way to connect the Haicom 403 BT cube as the included instructions tell different ways. the diagram shows the short fly lead(male ps2) goes to power and the female to gps. where as the written instructions have it the other way around. It is probably the diagram as i have managed to connect to a home pc but not my PDA, but thought it wise to double check. Tia
philpugh
PostPosted: Mon Dec 04, 2006 2:49 pm    Post subject: Reply with quote
If you have it working on your PC serial port then you will need to put a null-modem between the cable and your PDA serial port connector. A PDA serial port expects to be connected to a PC port (for data sync etc) so the transmit and receive pins (and associated control signals) need to be swapped around. You will probably get away with just swapping the transmit and receive pins in this case; as the cabling supplied by HAICOM doesn't have any of the control signals I believe.
HAICOM can provide a cable to connect to most PDAs
22.064 (26 Jun 24)
