Pocket GPS World :: View topic - 'brought to you by pocket gps world .com'
stevebrush
PostPosted: Sat Nov 25, 2006 11:56 pm    Post subject: 'brought to you by pocket gps world .com' Reply with quote
Hello, after upgrading my tom tom one to version 6.520 I lost my voice camera warnings. I downloaded the data chk file again and although the camera voice warnings have returned I get the spoken message 'brought to you by pocket gps world .com' before every camera warning. Any ideas how I can switch this off? thanks.
PostPosted: Sun Nov 26, 2006 2:32 am    Post subject: Reply with quote
Steve, have a look at the home page for a newer method for achieving spoken alerts using ogg files, this method allows a spoken alert for each poi loaded, there is no limit as you have using the data.chk file - Mike
For the link try HERE as it will disapear from the home page eventually.
Edit once to add link text MikeAlder
Jakle
PostPosted: Sun Nov 26, 2006 6:50 pm    Post subject: Reply with quote
That's the datachk file entry which the TomTom speed cameras use. Turn those off and the problem will go away.
stevebrush
PostPosted: Sun Nov 26, 2006 7:01 pm    Post subject: Reply with quote
Mike and Jakle thanks for your time and asistance. Could you tell me how to turn off the tom tom datachk Jakle.
PostPosted: Sun Nov 26, 2006 7:10 pm    Post subject: Reply with quote
Steve, which speed camera database are you using ? it could be:
Single file
Consolodated by type
Speed Zoned
I suspect you have more than a single camera database installed on your device, check how many ov2 files you have loaded on the card that state pocketgps_uk at the start - Mike
Jakle
PostPosted: Sun Nov 26, 2006 10:07 pm    Post subject: Reply with quote
I had this exact same problem with my 910. It's because you are running both theiin-built tt speed cameras and pocketgps. Simply disable the tt ones frrom the menu system.
stevebrush
PostPosted: Sun Nov 26, 2006 10:13 pm    Post subject: Reply with quote
Many thanks problem solved, Steve.
22.124 (26 Dec 24)
