Alang Occasional Visitor
Posted: Thu May 08, 2008 6:50 pm Post subject: Favorites- can I move? |
I am thinking of upgrading my i3 to a nuvi 300.
Can I transfer my favorites by using "Easy GPS" ?
Thanks in advance.
Alan |
The Rudd Regular Visitor
Joined: Apr 18, 2006 Posts: 121 Location: Newcastle upon Tyne
Posted: Fri May 09, 2008 6:13 am Post subject: |
I am not sure that if this can be done with an i3, as far as I know if you can locate your gpx file and take a copy then that holds your favourites.
Jerry |
Posted: Fri May 09, 2008 7:42 am Post subject: |
You can use EasyGPS (www.easygps.com) to save your Favourites from the i3 in a GPX file, then copy it to the Nuvi.
I did this somehow with my Nuvi. I had a folder called GPX and i copied the file there and rebooted the Nuvi. Then it loaded the favourites into the Nuvi favourites file called Current.GPX.
However i now prefer to load all my Favourites to a POI file instead as it makes it much easier to manage and move from unit to unit, leaving the Favourites for temp locations such as new cameras etc |
Posted: Fri May 09, 2008 5:38 pm Post subject: |
Thanks for the response guys.
I will give it a go.
Alan |
CaptainK Lifetime Member
Posted: Fri May 09, 2008 11:47 pm Post subject: |
PaulB2005 wrote: | However i now prefer to load all my Favourites to a POI file instead as it makes it much easier to manage and move from unit to unit, leaving the Favourites for temp locations such as new cameras etc |
Exactly what I do. Makes life very easy when you have multiple devices. |
