Pocket GPS World :: View topic - Haicom 204s software
p448
PostPosted: Mon Nov 06, 2006 12:36 pm    Post subject: Haicom 204s software Reply with quote
I need the software for installing my wired cable GPS receiver Haicom 204s. Can anyone point into the right direction?
I am trying to confiigure the GPS to recognise windows XP and work withHP IPAQ 1910 tom tom 5 pda.
philpugh
PostPosted: Mon Nov 06, 2006 3:06 pm    Post subject: Reply with quote
Don't know the unit but if it's a serial wired unit then you souldn't need any software - just get the correct cable to connect it to your PC or Handheld. The cables will be different as a handheld will require a null-moden type connector to reverse the data pins etc. You should then be able to use your s/w to connect to your GPS on COM1: (or what ever port you plug into on your PC.
A look at the haicom website www.haicom.com.tw for the full range of accessories for your device. I have a 305III with the pda cable for an iPaq 3660 and it works fine - no drivers needed.
PostPosted: Mon Nov 06, 2006 9:47 pm    Post subject: Reply with quote
I think this is a bigger problem than just finding the correct cable! - there are a number of posts within the forum indicating a lack of connectivity to this PDA other than IrDA or through the use of special cradle etc. Either click the search button then enter the following text to the search line
IPAQ AND 1910
This search entry brings up quite a few pages of information, a good start point might be to have a read of THIS - Mike
22.064 (26 Jun 24)
