bunch92 Occasional Visitor
Posted: Wed Oct 25, 2006 3:17 pm Post subject: Nuvi 310 Deluxe and POI displays |
I have a Nuvi 310 Deluxe and I couldn't find the answer to the following question on the forum:
- I loaded (using POI Loader) several POIs (in 1 go, all together). These POIs were speed cameras and shops (such as Tesco, Sainsbury, etc ...)
When I drive past a speed camera at high speed, I get the warning + the little camera icon on my nuvi screen. But when I drive past a Tesco/Sainsbury/etc.. , I DO NOT see anything on the screen. I set the alarm on for both customs POI and speed cameras.
If I do a POI search using the menus, all my Tescos/Sainsburys/etc .. can be found and I can create a route to them.
Now the "funny" thing. If I set these Tesco/Sainsburys/etc.. as favourite locations, they DO display on map !! huh ?
Anyone else has this problem ?
Thank you. |
swing Pocket GPS Verifier
Posted: Wed Oct 25, 2006 4:35 pm Post subject: |
That all sounds like it's working correctly to me - if you want alerts for the non speed cameras you will need to use POI Loader in manual mode and setup each alert individually (I think, I've never done that). |
Posted: Wed Oct 25, 2006 4:51 pm Post subject: |
swing wrote: | That all sounds like it's working correctly to me - if you want alerts for the non speed cameras you will need to use POI Loader in manual mode and setup each alert individually (I think, I've never done that). |
Oh I see. I used the automatic mode indeed. I will try the manual mode tonight and set an alert when within 500 meters.
I will let you know if it works. Thanks |
Posted: Thu Oct 26, 2006 10:12 am Post subject: |
Well , it sort of worked. On my way to work, I drove past something like 30 custom POIs, but the nuvi 310D only managed to get an alert for 1 tesco (with icon on map) and 1 Holiday Inn (without icon on map).
I set the alert to every POIs within 1000 meters (0.6 miles) so I should have had many more ....
Anyone else had that problem ? |
