Pocket GPS World :: View topic - SD card space for TomTom6
Planner2
PostPosted: Mon Oct 16, 2006 12:11 am    Post subject: SD card space for TomTom6 Reply with quote
Can anyone tell me how much SDcard space do you need for TomTom 6 running on a Ipaq HP5450. I have a 1GB SD card. Is that enough?
alix776
PostPosted: Mon Oct 16, 2006 12:16 am    Post subject: Reply with quote
for the uk more thn enough
device Lumia 950 xl
Burn1
PostPosted: Mon Oct 16, 2006 10:01 am    Post subject: Reply with quote
The whole of Western Europe takes about 900meg. I have GB and postcodes and France + Major roads of Europe and that is about 430meg.
Planner2
PostPosted: Mon Oct 16, 2006 9:52 pm    Post subject: Reply with quote
Hi Thanks for your reply. It is just that I noticed under the Western Europe map that there was one file 'Cline.dat' which is 924mb. Can I assume that all this file does not get loaded on the SD card?
alix776
PostPosted: Mon Oct 16, 2006 9:56 pm    Post subject: Reply with quote
have you got uk only or the seamless european one
device Lumia 950 xl
Planner2
PostPosted: Mon Oct 16, 2006 10:38 pm    Post subject: Reply with quote
the seamless european. I didn't know you could get a only uk map for TT6. By the way can you use TT5 Uk map for TT6 if I can't get the european map on the Sd card?
Planner2
PostPosted: Tue Oct 17, 2006 3:18 pm    Post subject: Reply with quote
Hi Can anyone answer my questions above?
Rybren
PostPosted: Tue Oct 17, 2006 9:11 pm    Post subject: TT6 on 1GB SD Reply with quote
I run TT6 with the seamless Western Europe map on a 1GB card. There's not a lot of extra space, but there is some.
I'm sure that you could also delete some files to free up more space, but I haven't gotten around to trying it yet.
Planner2
PostPosted: Wed Oct 18, 2006 12:06 am    Post subject: Reply with quote
When you load TT6 what is the process of installing only the UK map. At the moment there are files assciated with the western europe map that are in total over 1.5gb (i.e cline.dat 924mb, cnode.dat 295mb, faces.dat 253mb etc.). Does TT6 need all these files to be transferred to the SD card. If not, how do I load only the UK map?
PostPosted: Wed Oct 18, 2006 6:57 am    Post subject: Reply with quote
Planner2 wrote:
... in total over 1.5gb (i.e cline.dat 924mb, cnode.dat 295mb, faces.dat 253mb etc.).
It seems you have the V5 Western Europe Map, as used on the 700, in which case you can't split it up.
The new V6 Map comes on an SD Card I believe, at 900MB.
It it is the downloaded MOWE as shown on TT's Website then you can install one of 7 Maps, ie GB.
It would help if we knew which copy you have.
MarkHewitt
PostPosted: Wed Oct 18, 2006 10:42 am    Post subject: Reply with quote
The one which is available from the TomTom website i.e. "TomTom NAVIGATOR 6 - Software & Maps of Western Europe " is that one big seamless map or individual maps?
MikeM132
PostPosted: Wed Oct 18, 2006 4:53 pm    Post subject: Re: SD card space for TomTom6 Reply with quote
Most have given Europe answers. Just in case; TT6 takes about 977MB for US/Canada/Guam.
PostPosted: Wed Oct 18, 2006 7:29 pm    Post subject: Reply with quote
It looks as if it will do both!!
Detailed maps of 20 countries across Western Europe on DVD: Door-to-door navigation in 20 Western European countries. Choose from a combination of regional maps or install one connected map of all of Western Europe on a 1GB memory card (not included).
Planner2
PostPosted: Fri Oct 20, 2006 1:34 pm    Post subject: Reply with quote
Can anyone tell me whether TT6 works okay with HP5450 Ipaq because I have installed the application using the CD and when I try to run it I get the following error message 'cannot find 'Tomtom Navigator' (or noe of its components). Make sure the path and filename are correct and all the required libraries are availalbe' Does anyone know why I get this message?
alix776
PostPosted: Fri Oct 20, 2006 1:43 pm    Post subject: Reply with quote
does the 5450 run pocketpc2002 then i would think youll either have to upgrade the device to pocketp 2003 or 2003se from the hp website
device Lumia 950 xl
22.055 (29 May 24)
