Gambler Occasional Visitor
Posted: Thu Sep 28, 2006 2:59 pm Post subject: Renault Clio UV Coated Screen |
Can anybody tell me if the new TT1 V2 will work in a Clio without the need for an external ariel?
I thought the new processors in the x10 and the One improved the reception and therefore no need for an expensive aerial.
Thanks |
999tommo Frequent Visitor
![](modules/Forums/images/avatars/102097806847b5aca54fdd8.jpg)
Posted: Thu Sep 28, 2006 3:20 pm Post subject: |
I know it's not 'quite' the same, but I have the old TTOne which has the SirfIII chipset that is in the new version 2 device. I use it in Fords which have the heated front screens and have never had a problem, despite being told that heated screens and athermic screens (like Renaults) need an external aerial. _________________ Tommo...
Regularly absent, but still here in spirit ! |
Posted: Thu Sep 28, 2006 4:17 pm Post subject: |
999tommo wrote: | I know it's not 'quite' the same, but I have the old TTOne which has the SirfIII chipset that is in the new version 2 device. I use it in Fords which have the heated front screens and have never had a problem, despite being told that heated screens and athermic screens (like Renaults) need an external aerial. |
Cheers Tommo, just debating whether to buy one. Had a Garmin i3 previously but needed an aerial.
Shouldn't be a problem in the Meriva mind :o |
meestermartinho Regular Visitor
![](modules/Forums/images/avatars/1728261050443a799487593.jpg)
Posted: Fri Sep 29, 2006 11:03 am Post subject: |
Heated front screens like the ford dont cause the problems its the athermic ones that do. Mostly French cars.
sivogt Occasional Visitor
Posted: Fri Sep 29, 2006 1:46 pm Post subject: |
I have an athermic windscreen on a Renault Megane and for the Go910 need to use an external antenna. I assume the Clio has the same kind of coating as the Megane. |
Cleggy Occasional Visitor
Joined: May 30, 2005 Posts: 45 Location: Witney, Oxfordshire
Posted: Fri Sep 29, 2006 9:27 pm Post subject: |
The Ford Quickclear screen (Patented by them) is NOT the same as the solar reflective screen, available as an option on new cars.
The solar reflective screen gives off a mauvish tinge (really rare in my opinion (trust me I sell used Fords)) and I use the tom tom classic in my car with a quickclear all the time with no problems.
This has been mentioned zillions of times on here before.
Cleggy |
Stanley_Tweedle Regular Visitor
Posted: Fri Sep 29, 2006 11:11 pm Post subject: |
I have a Clio and needed the antenna for the Go700. Now I use the Navman 530 which is SirfIII like the TT1 and it has no trouble at all. So I can't vouch for the TT1 directly but I suspect it would be OK. |
