Pocket GPS World :: View topic - No Valid GPS Signal
No Valid GPS Signal
Powerman
PostPosted: Thu Sep 07, 2006 7:14 pm    Post subject: No Valid GPS Signal Reply with quote
Looking for fix for the following problem, if possible;-
Ipaq rx3715, BT 308 GPS, TTNav 5.210 withGPS driver v1.20.
Upgraded to above but unable to lock onto and get a signal in the "SHOW GPS STATUS" in TTN5, The bluetooth between PDA and GPS communicating ok.
In TTN "Specify GPS Hardware" yellow/blue disc spinning ok on the following settings. Baub rate = 34800, Bluetooth com port 6, on NMEA Device GPS and also on Other Bluetooth Device.
trevor.dowle
PostPosted: Sat Sep 09, 2006 12:19 pm    Post subject: Re: No Valid GPS Signal Reply with quote
Similar problem to me, and I had a similar set-up.
I know its no help, but after 3 weeks I bought a TomTom One. I think it was the GPS going duff, as everything else worked OK.
I hope the cure is permanent.
Regards
Trev Dowle
TomTom 730 T
philpugh
PostPosted: Fri Sep 29, 2006 2:43 pm    Post subject: Reply with quote
Before ditching the GPS unit.
I am assuming it worked OK before the upgrade to TT5.21 Smile
Do you see any signal strength meters in the TT GPS status screen at all?
If so - are they staying grey? Showing any meters means the GPS unit is 'seeing' satellites but may be having difficulties downloading the almanac data it will require to establish a fix.
Leave the unit on - outside with clear view of sky - for as long as possible - it can take a long time to get a lock in the (wrong) circumstances.
Try another bit of s/w. If you don't have any try OZIExplorerCE trial from www.oziexplorer.com and see if it communicates with your GPS - use the default world map - you are only interested in establishing correct communication.
Failing that go back to your working version of TT and see if it still works!
Phil
Powerman
PostPosted: Sat Sep 30, 2006 6:35 pm    Post subject: No Signal Reply with quote
Managed to get GPS Working with help from Alan on this site. Problem was resolved by changing the signal from NMEA to Serif. Now working ok.
THANKS
Powerman
PostPosted: Sat Sep 30, 2006 6:38 pm    Post subject: No Signal Reply with quote
Ooooops. Sorry wrong spelling "Sirf" signal
KenJ
PostPosted: Sun Oct 08, 2006 7:38 pm    Post subject: Reply with quote
I have the same problem - how do you with between the two ?
PostPosted: Sun Oct 08, 2006 7:42 pm    Post subject: Re: No Signal Reply with quote
I don't think the spelling is the issue, but could I point out that TTN5 will ONLY work with NMEA data, so you must have switched FROM SiRF to NMEA mode to get this working - Mike
22.055 (29 May 24)
