Pocket GPS World :: View topic - Brodit Navman ICN 510/520 dash mout
degringo
PostPosted: Thu Aug 31, 2006 12:56 pm    Post subject: Brodit Navman ICN 510/520 dash mout Reply with quote
Not sure if anyone is looking for an alternative to the standard Navman windscreen mount for 510/520 but I've just purchased a Brodit Mount # 215035 from www.siocommunications.co.uk
It evens holds the power cable in the mount so all you have to do is slide the Navman in.
High quality mount worth every penny IMHO
nortonbeak
PostPosted: Thu Aug 31, 2006 6:43 pm    Post subject: Reply with quote
I agree. Getting the bracket into the ventilator was a bit tricky, but once installed its as steady as a rock.
Only thing was that I got a bit of a rattle as the bracket must be a fraction of a millimetre too wide. A couple of strips of sellotape around the bottom edges of the Navman has fixed the rattle.
Navman ICN 520
512 Mb Cygnet SD card
Smart ST 2005 + SP 1
Peet090
PostPosted: Sat Sep 02, 2006 1:05 pm    Post subject: Reply with quote
I also use a Brodit mount - which I find works brilliant
Funnily enough , I also had a slight rattle and considered ways to deaden the rattle . I then read a posting on this site that mentioned the rattle was not from the unit fitting in the Brodit mount , but from the removable pointer fitted into the Navman unit.
Sure enough when I removed it the rattle disappeared - now I am more careful replacing the pointer to ensure it doesn't create a rattle
Maybe worth a try
b rgds
22.063 (19 Jun 24)
