Pocket GPS World :: View topic - Long/Lat to graph/map
acid2000
PostPosted: Mon Aug 21, 2006 3:53 pm    Post subject: Long/Lat to graph/map Reply with quote
I'm trying to convert longditude/latitude data into a graph. Given that the data will be for an area < 500km a flat earth approximation seems good.
What is the best way to convert my data to cartesian XY coordinates?
The current method I'm using seems off when compare to http://www.gpsvisualizer.com.
Thanks for any help
PostPosted: Mon Aug 21, 2006 10:53 pm    Post subject: Reply with quote
Keep in mind that you won't have a rectangle, even if you assume a flat earth. The longitude lines will be straight (but not parallel!) but the latitude lines won't
500 km is already way too much to neglect that.
acid2000
PostPosted: Tue Aug 22, 2006 1:17 pm    Post subject: Reply with quote
Sorry wrong number, my data is within 1mile.
The graph I have is similar to that of gps visualiser but seems in the wrong aspect ratio. Is there not a stock formular for conversion?
David_A_James
PostPosted: Tue Aug 22, 2006 6:03 pm    Post subject: Reply with quote
Whereabouts in the world is your data?
If it's in the UK, the Ordnance Survey website has formulae for converting from lat/long to OSGB eastings and northings.
David_A_James
PostPosted: Tue Aug 22, 2006 6:08 pm    Post subject: Reply with quote
There's a spreadsheet containing these at http://www.bangor.ac.uk/is/isx025/osgb.xls courtesy of Phil Brady who also has a FAQ on this topic at http://www.bangor.ac.uk/is/isx025/osgbfaq.htm
PostPosted: Tue Aug 22, 2006 6:23 pm    Post subject: Reply with quote
If you are in the lower part of the UK then you can roughly assume a ratio of 1 to 0.6 for latitude to longitude.
harryparkes
PostPosted: Sun Sep 17, 2006 8:22 pm    Post subject: Reply with quote
A bit late in replying.
To get the correct aspect ratio divide the longitudinal difference by the cosine of the mid-latitude. So for lat 50 deg the factor is cos 50 = 0.64279.
Harry
harryparkes
PostPosted: Sun Sep 17, 2006 8:29 pm    Post subject: Reply with quote
Not only late but wrong! I should have said mutiply.
Harry
23.054 (28 May 25)
