Rodonn Occasional Visitor
Posted: Sun Aug 20, 2006 4:12 pm Post subject: POI loader crashes on trying to load GPX files |
I think it may be something to do with my install, but I've upgraded to 2.3.2 and Ash's new POI loader that produces a GPX file for the cams. When I try to upload the GPX everything jusy hangs.
Any thoughts? _________________ Garmin StreetPilot i3
maps - v8
f/w - 2.7 with Audio 2.00
GPS Mode - WAAS/EGNOS
Snooper OEM repeater ant. routed to rear parcel.
Snooper Neo S3R user.
Tried - 2.9 (not a good time) |
IanE Occasional Visitor
Posted: Mon Aug 21, 2006 9:54 am Post subject: |
When I tried Ash's camera updater.exe over the weekend, when uploading the POIs to the SD card, the app appears to hang (100%CPU etc) but it did recover and work fine. |
Posted: Mon Aug 21, 2006 1:15 pm Post subject: |
I used Camera Updater and POILoader 2.3.2 yesterday. Worked fine. The GPX files are huge and can take several minutes to load onto an i3. Leave it for 5 minutes and it should complete.
Please be aware Ash10 has two programs Camera Updater (the old one) and Camera Manager (the new one). Can you clarify if you where using CU or CM?? |
Posted: Tue Aug 22, 2006 1:24 am Post subject: |
CM the new one.
It doens't seem to be a lag since the data screen isn't appearing when it fails.
I'll try again next month when the new update comes out. _________________ Garmin StreetPilot i3
maps - v8
Posted: Tue Aug 22, 2006 8:14 am Post subject: |
Quote: | It doesn't seem to be a lag since the data screen isn't appearing when it fails. |
What does that mean please?
It will appear that nothing is happening for quite some time then at the last minute the screen will change on the i3 and the update will complete.
I don't use the CM. I use the CU with no problems. |
