LESLIEAD Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Posted: Fri Aug 18, 2006 1:00 pm Post subject: Error when converting csv to gpx |
PocketGPSWorld.com Speed Camera Database Version 4.075 17 August 2006 I am getting an error when converting csv file for uk mobile to gpx it shows popup type mismatch.
Any Ideas on correcting this
Kind Regards
Leslie |
missing_user
Posted: Fri Aug 18, 2006 1:57 pm Post subject: |
Why are you converting to .gpx when the downloaded database has them as .gpx anyway? |
swing Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Fri Aug 18, 2006 2:16 pm Post subject: Re: Error when converting csv to gpx |
LESLIEAD wrote: | PocketGPSWorld.com Speed Camera Database Version 4.075 17 August 2006 | Yes, there's a problem with the data. Open the Mobile CSV file, and scroll do to the following Mobile cameras:
22205
22206
22208
22212
22468
On each the 3rd value is wrong: it says things like MOBILE:22205@54.5995 - remove the '@' and everything afterwards, and the file will then work.
What's happened is it looks like a copy'n'paste error in that instead of the speed being listed, the latitude (from the 2nd value) is there instead, and the convertor can't cope with it.
Unfortunately, these are all new cameras this month, so there's no equivalent entry from last month to provide the correct speed for these cameras. |
BoneMan1946 Occasional Visitor
![](modules/Forums/images/avatars/gallery/003.gif)
Posted: Fri Aug 18, 2006 2:16 pm Post subject: |
Quote: | Why are you converting to .gpx when the downloaded database has them as .gpx anyway?
To add the special features via Ash10's software ? |
Posted: Fri Aug 18, 2006 3:35 pm Post subject: |
Thanks swing
Regards
Leslie |
welshgasman Regular Visitor
Posted: Mon Aug 21, 2006 8:29 pm Post subject: |
Nice one Swing.
I had the same problem.
Perhaps it could be tested before the files are released.???
The other month I had a similiar problem with a download.
I *thought* that the gpx files took up less space.?
Am I wrong in this?, which is why I was using it.
TIA |
