dvhttn Occasional Visitor
Posted: Fri Aug 18, 2006 12:04 pm Post subject: garmin i3 longer suction cup mount? |
Newbie here but managed to get my i3 set up with 2.7 firmware, all POIs and the speed camera database. So far so good ... the only gripe I have is that on both of my cars the screen suction cup mount keeps the i3 a little too far away for easy viewing, especially with its small screen. I've looked at the Garmin site and seen a replacement mount the same size and a dashboard mount but not a longer suction mount.
Has anyone seen one/got one? Experiences? Has anyone tried the optional dash mount from Garmin?
All comments welcome ... _________________
Carpe diem ....... |
Posted: Fri Aug 18, 2006 3:00 pm Post subject: |
... just to add that I have looked at all the options on this forum BUt the sticking point seems to be having a ball/socket joint on the end of the mount as the garmin one does. Any suggestions appreciated ...
Oh, I will try the sucker on the dash but I have a feeling it won't stick ... _________________
gilesme Regular Visitor
Posted: Fri Aug 18, 2006 3:58 pm Post subject: |
I got one of these...
http://www.gpsw.co.uk/details/prod2991.html
No suction mount required, mount it where you want, doesn't move when "making good progress", no suction mark on the windscreen alerting the scrotes that I have a GPS.
Not cheap, but then i got my I3 for £99 ! |
mk_graham Regular Visitor
Joined: Jul 13, 2006 Posts: 200 Location: Milton Keynes UK
Posted: Fri Aug 18, 2006 7:11 pm Post subject: |
dvhttn wrote: | ..
Oh, I will try the sucker on the dash but I have a feeling it won't stick ... |
I reckon it will if you use the 'red disc' that came in the box. _________________ Garmin i3 gone (sold on eBay)
V7 PMD 1400 with Western Europe Maps gone (sold in local paper)
TomTom Go 720 WE Maps (for sale)
iPhone with Sygic Mobile Maps (Europe) - having problems |
bennnneb Occasional Visitor
Posted: Fri Aug 18, 2006 7:33 pm Post subject: |
mine melted to the windscreen in the heatwave we had. |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Fri Aug 18, 2006 7:35 pm Post subject: |
I have the same problem with seeing the i3 when the mount's attached to the windscreen, but I find the supplied disc works well on the dash of my Ford Ka:
The disc at a crazy angle on the dash looks a bit strange when the i3 isn't in use, but I can put up with that!
_________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Fri Aug 18, 2006 7:37 pm Post subject: |
Ahhhh! So that's what that's for! Having worked in IT support I really must listen to my own advice and RTFM .....
It says 'permanent' though. Anyone sucessfully removed one without pulling our half the dash? I'd still rather a longer ball & socket mount ...
Ta anyway - I will check it out. _________________
Posted: Fri Aug 18, 2006 7:48 pm Post subject: |
dvhttn wrote: | Having worked in IT support I really must listen to my own advice and RTFM |
I assume you're of the masculine gender!
dvhttn wrote: | It says 'permanent' though. Anyone sucessfully removed one without pulling our half the dash? I'd still rather a longer ball & socket mount |
Yes. I stuck it to a vertical surface first, but kept knocking it when I used the indicator. Got it off by sliding a knife blade under it without too much trouble, but it was during the very hot weather. No damage to the car, but it screwed up the adhesive pad on the back of the disc. I phoned Garmin and received a free replacement from them the following day. _________________ Anita
UK map 1130.12368
Posted: Fri Aug 18, 2006 8:09 pm Post subject: |
Anita wrote: | dvhttn wrote: | Having worked in IT support I really must listen to my own advice and RTFM |
Bet you only guessed 'cos I sign 'Dave' ...... :D
Yes. I stuck it to a vertical surface first, but kept knocking it when I used the indicator. Got it off by sliding a knife blade under it without too much trouble, but it was during the very hot weather. No damage to the car, but it screwed up the adhesive pad on the back of the disc. I phoned Garmin and received a free replacement from them the following day. |
OK. So I can use the old hair-dryer trick to soften it up. That's cool ....
Ta muchly! _________________
Posted: Fri Aug 18, 2006 8:38 pm Post subject: |
dvhttn wrote: | Bet you only guessed 'cos I sign 'Dave' ...... :D |
I didn't notice that!
dvhttn wrote: | OK. So I can use the old hair-dryer trick to soften it up. That's cool .... |
Don't think it'll soften it up if you have the hair-dryer on cool! _________________ Anita
UK map 1130.12368
Posted: Fri Aug 18, 2006 9:07 pm Post subject: |
Anita wrote: | Don't think it'll soften it up if you have the hair-dryer on cool! |
Now that's worth a large groan .......... _________________
welshgasman Regular Visitor
Posted: Sat Aug 19, 2006 2:43 pm Post subject: |
I bought one of these
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=34774&highlight=
and using part of a can holder made my own mount which hangs off one of the vents. Easily removed, further into the car so that sunlight does not affect it as much. Works well. The bolts to fit can be had from a small pack in halfords.
dvhttn wrote: | ... just to add that I have looked at all the options on this forum BUt the sticking point seems to be having a ball/socket joint on the end of the mount as the garmin one does. Any suggestions appreciated ...
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Sat Aug 19, 2006 5:28 pm Post subject: |
the nuvi mounts are a couple of inches longer and, in my opinion, actually have a morepowerful suction. you could try oneof them
MaFt |
