Pocket GPS World :: View topic - Speed camera accuracy - incorrect speeds
jjwd1976
PostPosted: Thu Aug 17, 2006 9:29 am    Post subject: Speed camera accuracy - incorrect speeds Reply with quote
I recently downloaded the speed camera database and was annoyed to find that virtually every speed camera had the incorrect speed assigned to it. For example all of the cameras on the A14 between Cambridge and the M6 were denoted as 43 mph and not 70. In the end I had to switch the nav unit off to get rid of the permanent warning tone. Also the speed camera near home was denoted as 25mph - not 40.
Do I have an incorrect setting on my Garmin 350?
Thanks in advance
missing_user
PostPosted: Thu Aug 17, 2006 11:06 am    Post subject: Reply with quote
That are many locations on that stretch of road, but 2 or 3 are 40mph, the remaining locations are 60 or 70mph M or F categories!
I can see all the database on the PC using MapSource and the database .gpx file!
Give me a particular location to check!
neil01
PostPosted: Thu Aug 17, 2006 11:15 am    Post subject: Reply with quote
I think that it is too much of a coincidence that 25mph is 40kph and that 43mph is 70kph.
I think we have a bit of 'units' confusion. I would double check all the settings on whichever hardware base is used, not just those within the application.
Anita
PostPosted: Thu Aug 17, 2006 11:17 am    Post subject: Re: Speed camera accuracy - incorrect speeds Reply with quote
Thanks in advance
Welcome Welcome to the forum!
It sounds as if you might have either your device or POILoader set to KPH instead of MPH.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
peterc10
PostPosted: Thu Aug 17, 2006 3:09 pm    Post subject: Reply with quote
From other posts this is usually because you have the POI loader software you use to put the cameras onto the Garmin set to metric (which is the default) rather than imperial. Reload changing the settings and it should be correct.
Peter
HTC Sensation
Copilot for USA
Skippy
PostPosted: Thu Aug 17, 2006 3:47 pm    Post subject: Reply with quote
It sounds like this is an easy enough mistake to make, maybe the install guide should be updated to tell users to check the setting - this one is catching out quite a few people by the sounds of it!
Gone fishing!
jjwd1976
PostPosted: Thu Aug 17, 2006 4:02 pm    Post subject: Reply with quote
Thanks for the info - I will reload the data and check the settings.
Anita
PostPosted: Thu Aug 17, 2006 4:31 pm    Post subject: Reply with quote
The one for the i3 does mention it
8 ) You can now change the distance & speed to feet and mph if required.
but there don't seem to be detailed guides for other Garmins.
Anita
UK map 1130.12368
Samsung Galaxy S21
22.071 (03 Jul 24)
