Pocket GPS World :: View topic - Navman iCN530 Speedcamera POI's
astrali
PostPosted: Wed Aug 16, 2006 10:52 pm    Post subject: Navman iCN530 Speedcamera POI's Reply with quote
Question
I have loaded the speed camera database to my iCN 530 quite easily. On trying to load all Tesco, Sainsburys and Asda POI's (for petrol stations) I could load the data but have noticed that for say Tesco POI's only 99 are visible in the menu. I can overcome this by loading 2 sets of POI's for Tescos with a max of 99. This led on to look at the max number of POI's for GATSO_30 and only 99 are listed but there are well over this in the pocketgps_uk_gatso_30 csv file.Therefore the speed camera database is not fully loaded probably for a lot of the other files as well.Is there a way to get around this. Also is there a max number of safety POI's and a max number of different POI files that the iCN530 can hold as it appears to be 71 as although I loaded more POI files without a problem they are not shown in the POI index on the iCN530.
Thanks.
Tim Buxton
PostPosted: Thu Aug 17, 2006 6:56 am    Post subject: Reply with quote
Although only 99 Tesco stores will show in the list, they are all there, so you don't need to separate them into two files. It is just a name display limitation in the 'Find' function. If you input a letter, say 'T' then you will display all locations from 'T' onwards. This may stop at 99 if there are more than 99 from 'T' to 'Z'.
If you search the Gatso file you will find the same limtation.
The max number of Custom POIs which can be active at any one time is 25, although some people have foud themselves only able to activate 16.
Tim
astrali
PostPosted: Thu Aug 17, 2006 9:20 am    Post subject: Reply with quote
:D
Thanks, will reload the complete files.
22.071 (03 Jul 24)
