markthomas999 Occasional Visitor
Posted: Tue Aug 15, 2006 8:38 am Post subject: Garmin POI Loader |
HI hope someone can help, i have loaded the POI’s to my computer but have problems loading on to my NUVI with the POILoader it is always saying can not find the csv file. |
Scarecrow Lifetime Member
Posted: Wed Aug 16, 2006 12:50 am Post subject: |
Have you unzipped the downloaded file? |
Posted: Wed Aug 16, 2006 8:11 pm Post subject: |
Its not in a win zip format |
Posted: Thu Aug 17, 2006 1:11 am Post subject: |
I am assuming you are talking about the Speed Camera files downloaded from this site when you talk about POIs, in which case they should be a zipped file (they always have been for me when I've downloaded them from here).
If you are talking about other types of POI, you need to make sure that they are all stored in the same file as any other POIs/cameras that you load to your unit, as POI Loader will always overwrite existing data when making a transfer, so all data needs to be transferred in one go. Hence the need to store everything in the same folder prior to transfer. |
Posted: Thu Aug 17, 2006 1:16 am Post subject: |
edited to add: Also, if you are talking about POIs rather than speed cameras, there are several types of file out there, depending on what type of Sat Nav they are destined for. This means that if you have downloaded POI files intended for a Tom Tom, they will be in a different format than can be used on a Garmin.
If you have POI Edit installed on your computer, it enables you to convert POI files from one format to another. Just open the file in POI Edit, and after clicking 'SAVE AS' select .csv as the type of file you wish to save. |
