rjm67 Occasional Visitor
Posted: Sat Aug 05, 2006 7:27 pm Post subject: How to restore original maps on Streepilot |
Hi all,
Tried to be clever today and add some spanish maps to my i3. Sadly, all I've managed to do is make it so that when I start the unit it says I should the pc to plan routes. (I was adding the maps via mapsource 8)
Any help to get the original maps back would be appreciated.
Cheers |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Sat Aug 05, 2006 9:33 pm Post subject: |
if you have tried to copy the new mapping onto the original card then you have lost the uk maps... _________________ *************************** |
kikura Occasional Visitor
Posted: Sun Aug 06, 2006 11:27 pm Post subject: |
.... but if you ask Garmin support very nicely, they might reprogram the card for you at no extra charge. That's what they did for me (I was so relieved) and at least one other person on these boards. :D |
muzizzles Occasional Visitor
Posted: Mon Aug 07, 2006 1:19 pm Post subject: |
I think this is what I've done too.
I put some maps onto the card and now nothing works, the i3 shows a message asking me to use the install CD, which I don't have.
Are the UK maps supplied on the transflash or are they hard coded into the machine? |
Posted: Mon Aug 07, 2006 1:38 pm Post subject: |
muzizzles wrote: | I think this is what I've done too.
depends if yours came with a card or not...if it came with a card then the mapping is on the card...if no card then its loade on the i3 itself...(sorry, a bit obvious) _________________ *************************** |
Posted: Mon Aug 07, 2006 1:48 pm Post subject: |
yeah it came with a card, so it's cattled?
only got it yesterday |
Posted: Mon Aug 07, 2006 1:53 pm Post subject: |
yep....... _________________ *************************** |
Posted: Mon Aug 07, 2006 1:56 pm Post subject: |
argh, what do i do? |
Beerbellybill999 Regular Visitor
![](modules/Forums/images/avatars/gallery/003.gif)
Posted: Mon Aug 07, 2006 2:05 pm Post subject: |
muzizzles wrote: | argh, what do i do? |
It looks like you will have to contact garmin and plead insanity and hopefully they will sort it out for you under G'tee(as done with others before you) _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed) |
Posted: Mon Aug 07, 2006 2:09 pm Post subject: |
muzizzles wrote: | argh, what do i do? | or try and take it back and see if they will exchange it.(if you say it was faulty) _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
argh, nightmare
so I can't use City Select Europe to put maps on it?
that' show I messed up originally |
Posted: Mon Aug 07, 2006 2:24 pm Post subject: |
muzizzles wrote: | argh, nightmare
if you have a copy of this with unlock codes then you can still use it but I would suggest either you return the unit for an exchange and then buy a new transflash card to put City selct on or return unit to Garmin and again buy a spare transflash card.
But whatever you do make sure you back up your main Map card to your hard drive so that you can restore it if this ever happens again. you can restore it but only to the original card! _________________ i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
