Pocket GPS World :: View topic - garmin i3 lost map
garmin i3 lost map
GTCARLING
PostPosted: Wed Aug 02, 2006 9:13 pm    Post subject: garmin i3 lost map Reply with quote
I recently purchased the garmin i3 and have been most happy with it. I was loading the speed cameras etc from this website, when it had finished i noticed that the map disappeared there is no longer any poi`s or postcodes its completely empty. I have obviously deleted the map somehow, please help.
timber
PostPosted: Wed Aug 02, 2006 10:10 pm    Post subject: Re: garmin i3 lost map Reply with quote
Welcome to the forum.
First time I have heard of this fault Question
Anyway try the following full reset.
With unit switched off hold down left hand button, hold down thumbwheel and finally hold down right hand button (all three buttons together) select yes and tell us what the result is when the unit restarts up (all settings will be at factory default)
GTCARLING
PostPosted: Wed Aug 02, 2006 10:17 pm    Post subject: Reply with quote
Thanks man thats fixed it, i was putting some poi`s on it last night and half way through crashed out. When i checked to see if they had been loaded on noticed everything had gone and there was no map i`ll try again and hopefully do it right this time.
timber
PostPosted: Wed Aug 02, 2006 10:25 pm    Post subject: Reply with quote
Delete what ever you have in the POILoader folder you used to load to your I3.
Suggest you do not install the single file, go for the speed zoned or the Consolidated by type. Thumbs Up
GTCARLING
PostPosted: Wed Aug 02, 2006 10:36 pm    Post subject: Reply with quote
Thanks man will do, thanks for your help.
GTCARLING
PostPosted: Wed Aug 02, 2006 10:43 pm    Post subject: Reply with quote
Can i ask you another question when i express install the poi`s what proximity does it set ie default rather that manually changing them all.
22.064 (26 Jun 24)
