Cupra-Matt Occasional Visitor
Posted: Wed Aug 02, 2006 7:03 pm Post subject: stoopid question? |
Where is the cheapest place to get a bluetooth gps receiver? was given an emtac crux11 btgps but as it is sirf it wont work with my tomtom.
also my missus broke the suction cup out of my dell mount/charger/input base.
need t replace but was hoping to get away from the untidy cable ridden dash.
any ideas the cheaper the better. |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Wed Aug 02, 2006 7:11 pm Post subject: |
Why not switch the reciever back to NMEA mode? I have seen other posts elsewhere where the unit will work in NMEA mode, or are you confusing the chipset name SiRF with the data output protocol which can be SiRF or NMEA (NMEA is what TomTom requires) - Mike |
Posted: Wed Aug 02, 2006 7:51 pm Post subject: |
no software with the bt gps. was the only thing left behnd by the car thieves at an airport. took the charge lead and everything else.
just have the gps itself and a little leather pouch.
is there anywhere I can get the instructions?
cheers for the fast reply again mike. |
Posted: Wed Aug 02, 2006 10:39 pm Post subject: |
have imported the tomtom gps 2.06 to my memory card in the tomtom section, not maps or anything. when i find it on my pda it says no application to open.
where have i gone wrong? where do the files need to be after i have extracted them from winrar? |
Posted: Wed Aug 02, 2006 10:47 pm Post subject: |
When you have downloaded this file and used winzip to unzip the file you should have been presented with a single file named ttgps_arm.CAB it is this that needs to be copied to the card then run, by tapping it within file explorer on the PDA - I suspect you have unzipped the file too far, give it another go as per detailed above - Mike |
