Pocket GPS World :: View topic - Metroguide USA v5. Please help
Goto page 1, 2, 3, 4  Next
sanaar
PostPosted: Wed Aug 02, 2006 8:43 am    Post subject: Metroguide USA v5. Please help Reply with quote
I have an i3, runnung 2.7.
Purchased Metroguide USA v5 maps and loaded img2gps utility.Also 1gb card.
Anyone know where I can find an idiots guide to transferring maps to my i3.
Been trying for 2 days now and ready to give up.
Beerbellybill999
PostPosted: Wed Aug 02, 2006 8:55 am    Post subject: Reply with quote
here
I hope this helps
Its very easy to get it to navigate(and also loads POI from metroguide) but its a bit more tricky to get the seach address search facility(indexed) but I have done it following this guide
Even withouth the seach you can load your own favourites with Mapsource before you go!
i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed)
Beerbellybill999
PostPosted: Wed Aug 02, 2006 9:20 am    Post subject: Reply with quote
I have found a wizard that does it all for you
http://www.geodude.nl/gps/index.php
I did it the long winded way!
sanaar
PostPosted: Wed Aug 02, 2006 9:25 am    Post subject: Reply with quote
Cant thank you enough for your fast reply.
Will try when I get home from work.
I am currently on ver2.7.
I heard somewhere that you need ver2.9 or above to load new maps.
Do you know if this is correct?
sanaar
PostPosted: Wed Aug 02, 2006 10:07 am    Post subject: Reply with quote
when the new maps are uploaded to the card and inserted into the i3, should the maps appear on screen or do you need a satellite fix before the maps appear.
How do i know its loaded and ready to work before i actually try the i3 in the U.S.?
Beerbellybill999
PostPosted: Wed Aug 02, 2006 10:45 am    Post subject: Reply with quote
I have 2.7 and the old method worked with me( see my signiture) but I have not tried this new wizard. I have heard though that you wil need upload the final step via a card reader rather than the i3 itself(and select the card/drive in sendmap as sometimes the utlity will freeze.
the 2.9 problem you refer to is only for people with Map data loaded internally and not on a seperate card!
Let us know how you get on
Beerbellybill999
PostPosted: Wed Aug 02, 2006 10:49 am    Post subject: Reply with quote
I forgot to answer your second question.
When the map is successfully loaded you will be able to zoom out and you will see the maptiles that have been loaded and you will also see new poi loaded.
As long as you see these. it will work in the usa!
sanaar
PostPosted: Wed Aug 02, 2006 2:33 pm    Post subject: Reply with quote
I have selected the maps i require and they are showing in the left hand window of mapsource.
When I try and "save as" the only options I have is Mapsource file *.mps.
I dont have an option as *.gdb
Any ideas?
Jamas
PostPosted: Thu Aug 03, 2006 8:01 am    Post subject: Reply with quote
Any ideas?
Check the version of Mapsource; should be 6.91 or above otherwise go there for an update: http://www.gpsinformation.org/perry/msource/
Jamas (also using MG on my i3 Wink )
SP i3 S/W 2.9-> 2.7 City Navigator V8 NT+
Beerbellybill999
PostPosted: Thu Aug 03, 2006 9:55 am    Post subject: Reply with quote
The Metrowizz ultility from Geodude is BRILLIANT!!!!!
I have always done it manually and to be honest it was a bit tricky but this new utility make it so easy. I even did it without a card reader!
My i3 has the mapping on an external transflash card. I took out the UK on and loaded my new map on a new card.
I transferred a new mapset within a matter of minutes!!(only a small map of NW England)
It Navigated and also had address search and POI loaded automatically.
GEODUDE is The MAN!!!!
PS make sure for update the Mapsource program to the latest(free update from Mapsource)
sanaar
PostPosted: Thu Aug 03, 2006 3:09 pm    Post subject: Reply with quote
Worked a treat. fantastic utility.
Loaded 256mb mapset in no time after 2 days of trying.
Much appreciated Beerbelly.
Beerbellybill999
PostPosted: Thu Aug 03, 2006 3:17 pm    Post subject: Reply with quote
No probs I am glad I can help!
Beerbellybill999
PostPosted: Thu Aug 03, 2006 3:54 pm    Post subject: Reply with quote
Nearly had a heartattack. I left my 256mb original map card in i3 by mistake!
It deleted my UK Map that came with the unit
Phew!!, I am glad I had backed this up to my hard drive. I copied this back and YES i can report that re can re-instate backup as long as its back to the original card.
A word of advise for everyone,BACK UP YOUR MAPS!!!!!!!!
zogman
PostPosted: Thu Aug 03, 2006 4:28 pm    Post subject: Reply with quote
thanks mate..i think you are the first one to 'prove' that this can actually be done...
sanaar
PostPosted: Thu Aug 03, 2006 4:52 pm    Post subject: Reply with quote
beerbelly,
Loaded eerything successfully for usa mapping.
when i search for a city i only get cities contained in 1 maptile listed.
i have loaded 256 maptiles.
Is there a way to search for any city or change the maptile that is shown.
Also there doesnt seem to be any POIs loaded.
Any advice?
Page 1 of 4
22.064 (26 Jun 24)
