PW Occasional Visitor
Posted: Sun Jul 30, 2006 5:10 pm Post subject: Help Installing TT USA on PDA |
Been successfully using TT5 UK on my ipaq2210.
I also have TT USA which I have not needed to use - but I do next month.
The version I have is based on TT3 I believe.
So, the S/W consists of 8 CDs. But none of them appear to have an option to install the app itself. I uninstalled TT5 first but still have the maps on the SD card.
I have tried installing the 3.07 application upgrade from the TT website.
This was partially successful. It sees the USA maps fine. But when I start the app it tells me I have no voices installed.
So my question is, am I missing a CD with the original app on?
All CDs have maps on and do run the setup.exe installation app. But none of them let me install the app.
I suspect the one I installed from the TT website is not the right app for the USA maps, hence the reason why I have voice problems.
Any suggestions of how to get this up and running.
Pete |
lbendlin Pocket GPS Staff
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Sun Jul 30, 2006 8:48 pm Post subject: |
All is ok (if a tad old). You simply need to find a set of WAV based voices on the web, and then place them into the "voices" subfolder of your TTN3 install. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Jul 31, 2006 1:23 pm Post subject: |
Thanks for the reply. For some reason there was no voices folder.
I found a solution by using my older TT2 USA CDs. You can install the voices from them. Seems to work ok.
Do you have any idea where the TT3 USA app should be on the CDs?
How many CDs should I have?
Pete |
Posted: Mon Jul 31, 2006 6:21 pm Post subject: |
You may find it on CD 8. It's been a long, long time ago, don't remember any more. _________________ Lutz
